06-11-2015, 03:31 PM | #1 |
cleaning and degreasing generator
I am cleaning and decreasing my generator in preparation for painting.
Started with commercial degreasers..did not work well! Tried Lacquer thinner did not work too much better! Maybe a Dremel tool with wire brush tool is the best? Any suggestion? commercial pvc Pipe cleaner solution? |
06-11-2015, 05:15 PM | #2 |
Re: cleaning and degreasing generator
Lacquer thinner evaporates too fast. Use Mineral Spirits and a good stiff nylon bristle brush. Oh, and a lot of elbow grease.
06-11-2015, 07:56 PM | #3 |
If I'm just degreasing, a spray can of brake cleaner works well for me.
Sounds to me like you're trying to remove more than oil or grease.
06-11-2015, 09:42 PM | #4 |
The windings in generators and starters are insulated with a varnish that will dissolve when exposed to solvents like lacquer thinner. This will cause a short. You may want to exercise some care so as to prevent it from getting inside the unit.
06-11-2015, 11:20 PM | #5 |
I cleaned the generators on my 36 Fordoor and 57 Studebaker inside and out with mineral spirits. Worked fine for both.
Tim Carlig |
06-12-2015, 01:51 AM | #6 |
