09-26-2022, 04:27 PM | #1 |
Idle help
Hi guys, i'm trying to get my roadster to run better. here is what i did. I adjusted the air to 1&1/2 turns out as per the Less Andrews , adjusted the idle speed to around 700rpm,in doing so i found an air leak and tightened the manifold bolts, running not bad but when i shut it down about 3 sec. later i get a back fire?? this seems to be my stumbling block. what am i missing?? any help? thanks THE HOOCH
09-26-2022, 05:33 PM | #2 |
Re: Idle help
Did you fix the air leak ? In other words, did you check it after you tightened the bolts ?
Setting the idle mix screw to 1.5 turns is a starting point. That screw adjusts air, not fuel. |
09-27-2022, 01:04 AM | #3 |
Re: Idle help
X2 on Patrick's comments. IMO, 700 seems a bit fast on the idle. When turning the key off, raw fuel may be reaching the exhaust and igniting. Our coupe idles around 550. Our engine has a high compression head and good compression numbers. Too fast an idle can cause shifting problems.
Check for leaks at the block to manifold, carb to manifold, hairline cracks in the intake manifold, windshield wiper line and fitting, throttle plate shaft, and a more obscure location is the throttle plate itself. (inside the upper half of the carb. It should completely close off the air when idle screw is backed off completely. Use a pen light to check for the fit in the bore? This info learned recently from Marshal Daut) I would reduce the idle speed at the idle rpm adjustment screw, then move the spark advance all the way up and close off the GAV just before turning the key off to see if the issue clears. When fuel related issue, Backfiring in the exhaust or muffler is sometimes referred to as after fire and is often a too rich mixture. Backfire in the carburetor is often a lean mixture.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" Last edited by Rob Doe; 09-27-2022 at 01:21 AM. |
09-27-2022, 02:14 PM | #4 |
Re: Idle help
Admittedly, retarding the spark to stop backfiring is only a band-aid masking the cause of chronic backfiring. But it's still better than hearing backfiring and possibly blowing out the muffler! Follow all the suggestions offered so far and you'll probably snare the cause of your problem. Marshall |
