Old 06-09-2015, 04:50 PM   #1
Paolo Volpe
Default Mounting front license plate
Hello Friends, What is the correct way to mount the front license plate on the headlight bar. Should the clamp part of the mounting bracket be up or the square part when put together with plate ? Thanks Paul
Paolo Volpe is offline   Reply With Quote
Old 06-09-2015, 05:19 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Mounting front license plate
Square part up.
Top holes of plate mounted with bolts in front of the clips.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 06-09-2015, 05:54 PM   #3
Paolo Volpe
Smile Re: Mounting front license plate
Thanks Jim
Old 06-09-2015, 07:35 PM   #4
Steve_Mack_CT
Steve_Mack_CT's Avatar
Yep, when I got my first "A" the local club guys told me that is how you tell a "veteran A-er" from a newbie!
Steve
1930 Model A Roadster
Steve_Mack_CT is offline   Reply With Quote
Old 06-09-2015, 07:50 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
The Model A first had the mounting bolts below the headlamp bar, but changed to being above the bar. It's in the SERVICE BULLETINS.
Old 06-09-2015, 11:28 PM   #6
Arlyn Bieber
So how did Henry intend for the license plate to be mounted when the '30 headlamp bar was slotted. Can't find this information in the Service Bulletins.
Arlyn Bieber is offline   Reply With Quote
