09-20-2010, 03:46 PM | #1 |
interior support bracket(spare tire)I.D.
On a Town Sedan('30 Murray), is there an inner body support piece(metal) that runs vertically from the belt rail down to the end sill? When the car was dismantled it did not have one(but other parts/pieces have been 'missing' too). The exterior spare tire mount would bolt to it.
The reason for the question is that I thought I found such a piece, but it doesn't look right(mainly the angles). It was among some Vicky parts, and was told it would fit all sedans. Pics attached. Thanks. Last edited by Brubaker; 09-20-2010 at 04:12 PM. Reason: change/alter title of thread |
09-20-2010, 04:21 PM | #2 |
Registered User
Re: interior support bracket(spare tire)I.D.
it appears that with a little modification you can make it work
here are two drawings done by Anders Ramberg and published in the Victoria clubs book seems that the top is different,the victoria has the clip for the seat back and bolts to the face of the belt rail the sedan has that same area bolted under the belt rail you should be able to cut the top off and weld a new top on all the dimensions are here tom |
09-20-2010, 09:10 PM | #3 |
Thanks Tom. Are those drawings for a sedan? What I have must be for a Victoria(because of the clip at top).
09-20-2010, 11:16 PM | #4 |
Registered User
thats correct
the sedan is on the left and the victoria is on the right the lower dimensions are the same the only difference is the very top the victoria has the clip for the seat backrest and screws to the face of the belt rail the sedan dosnt have the clip and the bracket top is different as it screws under the belt rail tom |
09-21-2010, 03:06 AM | #5 | |
09-21-2010, 04:07 AM | #6 | |
If you are going to modify the one you have, may I have the seat clip?
09-21-2010, 11:04 AM | #7 |
I'd rather not alter anything. Would rather sell the piece to someone who can use it. Will put it on The Swap Meet when I have a moment. Bruce
