09-09-2010, 09:01 PM | #1 |
Model A horn
Horn picking up a ground and runs continuous. Has anyone had this problem? The horn works great and checks out ok. But when grounded to the frame it will run and heat up at times.
Ron |
09-09-2010, 11:45 PM | #2 |
Re: Model A horn
The horn works by passing the voltage through the horn and up to the steering wheel where it is grounded. I would check the bottom of the steering box where the light and horn connections are made. If you have a reproduction harness anything can happen.
09-10-2010, 01:21 AM | #3 |
Re: Model A horn
Some of the poorer quality wiring harness terminal block horn connection will cock sideways and ground out in the switch.
Ron |
09-10-2010, 05:56 AM | #4 |
Re: Model A horn
Mine was doing that and the insulating washer between the frame and one brush holder was missing. I may have left it out before while trying to make it work.
I found it by using my ohmmeter probes at each point of the circuit until I found it. |
09-10-2010, 07:12 AM | #5 |
Re: Model A horn
1.disconnect the wires from the horn
2. take a 12 volt test light and connect it between the leads that go to the horn. it should flash as your pressing the horn button. this confirms your circuit is working properly if that ck's out then you may have a problem inside the horn http://www.pasetta.net/Model%20A%20T...ingdigram.html |
09-10-2010, 12:51 PM | #6 |
Re: Model A horn
You can make an insulating washer from thin fiberboard, or even an old credit card. Something like the cardboard from a cereal box WON'T make a good insulating washer. |
