02-15-2020, 09:37 AM | #1 |
need help from you wizz kids?
Question is, what happened to Google? which I use all the time. I click on google for example I type 1991 Ford L9000 wiring diagram (which we need
truck gauges are all dead ) I had these books, which I can't find. OK click enter and all I get is this stupid 'search encript' = Find here: L9000 diagrams at amazon.com or Ace hardware and more stupid, buy new L9000 at New England Ford dealers, say what, Ln's have not been made since Sterling or Freight liners. Google did work before new years but no more it just goes to this stupid 'search encript' and can't get rid of it. So how are you all googling but I can not ???? sam Oh please don't tell me another $200 for PC repair I just bought it.....junk |
02-15-2020, 10:07 AM | #2 |
Re: need help from you wizz kids?
You could try doing your search with Bing. www.bing.com
I use that instead of Google. Best of luck. Mike |
02-15-2020, 10:51 AM | #3 |
More and more ads and less and less information. Sometimes you have to get creative with the search parameters.
02-15-2020, 11:07 AM | #4 |
thanks guys sam shall try sorry it goes right back to search encript again????
02-15-2020, 11:12 AM | #5 |
02-15-2020, 11:37 AM | #6 |
'52 F-1, EAB flathead |
02-15-2020, 11:40 AM | #7 |
02-15-2020, 12:18 PM | #8 |
What Bob said above^...It's the best search engine...
02-15-2020, 04:04 PM | #9 |
Search Encrypt is a browser extension that somehow got added to your computer. It's an accessory for the browser of sorts. Depending on the browser, find the place where add-on's or extensions are managed, and remove it from the browser.
Another place to check in the browser is the default search provider, switch it back to Google or your preferred (legitimate) search engine, and remove the Search Encrypt. It may be even easier to use the Programs And Features in Control Panel to select it an uninstall it (if it shows up there, fingers crossed). Remember fellas, a lot of people search using the address bar which processes through your default search engine for that browser. You can also go to the search website and use their place to type your request. Here's Google's results for the phrase "removing search encrypt" https://www.google.com/search?q=remo...ncrypt&ie=&oe= If you add your browser to the end of that phrase you'll get specific results. Good luck.
02-15-2020, 06:33 PM | #10 | |
02-15-2020, 07:32 PM | #11 |
I tried DuckDuckGo for a while... I like that they don't track you like Google.
This particular issue is the borderline malware that is Search Encrypt. Certainly falls into the 'possibly unwanted program' or PUP category. It needs removing from the browser's default search. Try to catch a writer Geoffrey Fowler, he's done some epic stuff with browser/phone dangers.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 02-15-2020 at 08:53 PM. |
02-16-2020, 08:38 AM | #12 |
Thanks to all, with a stroke of luck I clicked on 'top right three dots' that opened settings
so, search encript got the axe. Now google now works. Why can't mfg. programmers speak english (words) instead looking like short hand, didn't have that in school 60 yrs ago. dots dashes wavy lines ugg. thanks sam |
02-16-2020, 11:03 AM | #13 |
What problem are you having with an LN 9000? I had a couple some time ago, I found out some of the circuits are ground activated , right backwards of most trucks , My e- mail is [email protected]. if you need further assistance, I started using aftermarket parts ( Horton fan hubs etc.) and wired some components reversed, through Bosch relays. I called mine a "Poor Boys' Peterbilt". most parts were captive market . Check the cab feed relay same as some 70s thunderbird headlight relays, tin box about 1""x 1 1/2" 3 wire plug.
Fordestes |
02-17-2020, 06:10 AM | #14 |
Thanks email sent sam
