Old 07-29-2019, 09:13 PM   #1
nb141fd
Default Rear Lower Trunk Panel
Does anyone know if any of the vendors sell a Coupe rear lower trunk panel with the correct arch built in? I've looked for an original but so far no luck. On a 30-31 coupe this panel is taller in the middle by about a 1/4" compared to the ends. I believe most of the reproduction panels are straight across both top and bottom and need extensive work to fit properly. TIA
Tony
nb141fd is offline   Reply With Quote
Old 07-30-2019, 10:33 AM   #2
100IH
Default Re: Rear Lower Trunk Panel
That would be nice. More to the needed shape then just the top edge though.
100IH is offline   Reply With Quote
Old 07-30-2019, 09:06 PM   #3
Tinbasher
Tinbasher's Avatar
Try Bert's. They have a lot of original panels. JP
Tinbasher is offline   Reply With Quote
Old 07-31-2019, 05:01 AM   #4
Oldbluoval
Oldbluoval's Avatar
I’d check with Bert’s on an original
However, I am currently completing a buck/template to make them correctly
Made a first run yesterday and have to make some minor adjustments
These have the correct arches etc. I have several originals to knock off from
Should have them in two week if all works out. Will be $95 plus shipping to wherever
These fit 28-29 coupe and all cabbys
If any interest get back to [email protected]
Old 07-31-2019, 06:57 AM   #5
desotoguy
Had a problem with repro panel being straight across the top. Could't find a good original replacement, but did find a bad original from which I took the top reinforcement bar and spare tire reinforcement and installed same in place on the repro panel which solved the problem.
desotoguy is offline   Reply With Quote
Old 07-31-2019, 07:42 AM   #6
Oldbluoval
Oldbluoval's Avatar
I tried the same thing. It sorta worked but the repo I had was too short and the gap at the base of the deck lid was too wide
That’s why I went the path of making them
We shall see how it goes
Old 07-31-2019, 10:30 AM   #7
nb141fd
Thanks gentlemen I appreciate the advice.
Old 08-01-2019, 11:02 PM   #8
Steve Plucker
Here is some data to help you along:
http://www.plucks329s.org/pdf/studie..._Part_%203.pdf
Pluck
Old 08-02-2019, 10:27 AM   #9
nb141fd
Thanks Steve, great info.
