03-23-2020, 09:14 PM | #1 |
Replacing rear qtr window
What is best to use to reset glass in Rear quarter window frame to seal it? It appeared to be some sort of rubberized window channel in the original.
03-23-2020, 09:46 PM | #2 |
Re: Replacing rear qtr window
What make and model of vehicle?
03-24-2020, 01:23 AM | #3 |
Likely is glass setting tape.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
03-24-2020, 07:36 AM | #4 |
1939 Ford Deluxe Fordor
03-24-2020, 08:33 AM | #5 |
Here's what you need.This is the rear 1/4 window of a 40 Ford coupe. Call Drake and see if he now has it in stock. Also, check with other vendors below. Don't know if Carpenter has it. I also used the sealant shown, although some say it's not required. That was in 1988. Still holding.
https://www.bobdrake.com/FordItem.aspx?Item=B-704220-B A SEARCH revealed this helpful information about the seals. https://www.fordbarn.com/forum/searc...rchid=15011464 and https://www.fordbarn.com/forum/showt...window+sealant and https://www.fordbarn.com/forum/searc...rchid=15011478 Check with C and G. https://cgfordparts.com/ufolder/cgca...&searchnumber= Last edited by 19Fordy; 03-24-2020 at 08:51 AM. |
03-24-2020, 08:51 AM | #6 |
03-24-2020, 11:23 AM | #7 |
Putting the glass in the swing-out rear window frames requires glass setting tape. I had to try a couple of different thicknesses to get a good fit on mine.
