Old 09-21-2019, 06:34 PM   #1
51504bat
51504bat's Avatar
Default 1954 Ranch Wagon Parts ID
Pulled the 239 Y Block and I'm starting to prep for the 302/AOD install and I need some help with a couple of parts(?). First the nut and stud on the upper fire wall below the windshield. It was covered with a glob of what appeared to be strip caulking. Before I crawl under the dash to investigate I thought someone would know what it is/does? Second question, there is what appears to be some type of rubber mount under the radiator but the radiator doesn't rest on it as far as I can tell. Things are much different in this project than the flathead in my '39 p/u so any help is much appreciated. I did look at my chassis manual but came up empty.
Old 09-21-2019, 07:03 PM   #2
HOTRODPRIMER
HOTRODPRIMER's Avatar
Default Re: 1954 Ranch Wagon Parts ID
It's been a long time since I built our '54 Ranch Wagon but as I recall it's a support rod for the clutch/brake assembly.
The 2nd piece is a worn out radiator support pad.HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 09-21-2019, 07:15 PM   #3
51504bat
51504bat's Avatar
Thanks HRP. I posted on the Flathead section of the Barn due to a brain fart. I'll go ahead and post on the later section as well.
Old 09-21-2019, 09:26 PM   #4
Bob C
2nd question, Front mount?
Bob
