Old 03-05-2012, 08:35 AM   #1
Forever In Stone
Default Ventilating the Flat Head!
Does the 8ba Flathead get enough ventilation through just the oil filler pipe? My motor does not have any other means other than this oil fill pipe.
Your thoughts please!
Thank you, Alan
[email protected]
Forever In Stone is offline   Reply With Quote
Old 03-05-2012, 08:54 AM   #2
Shadetree
Shadetree's Avatar
Default Re: Ventilating the Flat Head!
It should have a crankcase breather pipe on the intake manifold.
Shadetree
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 03-05-2012, 09:38 AM   #3
flathead4rd
flathead4rd's Avatar
Are you saying that you don't have a road draft tube on the front of the intake manifold?
flathead4rd is offline   Reply With Quote
Old 03-05-2012, 09:48 AM   #4
36tbird
There needs to be an "inny" and an "outy".
36tbird is offline   Reply With Quote
Old 03-05-2012, 10:18 AM   #5
Seth Swoboda
Seth Swoboda's Avatar
You could put a PCV valve in place of the road draft tube and run the line back into the carb.
Seth Swoboda is online now   Reply With Quote
Old 03-05-2012, 10:28 AM   #6
peteyshoes
alan, mine is the same as yours, filler tube only. however---i have a small vent on the side of oil pan that seems to pull some air in. this is factory original. it appears there were many variations on these engines.
peteyshoes is offline   Reply With Quote
Old 03-05-2012, 10:34 AM   #7
dduke
dduke's Avatar
Not all intakes are created equal. I ran a super dual with a pair of Holley 94's that had a fitting and tube that went back to the breather/oil fill tube at the rear of the intake. My current offy and single quad is set up a bit different and the breather at the rear is fine. I use the fitting at the rear of the intake below the carb as my vacuum and trani set-up.
dduke is offline   Reply With Quote
Old 03-05-2012, 10:38 AM   #8
Mike in AZ
Mike in AZ's Avatar
Petey, are you talking about the vent at the passenger bottom front of the engine??.....that's your down draft tube to let the fumes out.....Mike
Mike in AZ is offline   Reply With Quote
Old 03-05-2012, 10:46 AM   #9
Old Henry
Old Henry's Avatar
I'm not sure about 8ba but here is the illustration from the Ford Passenger Car Sales Handbook for the 59A-B showing the path of crankcase ventilation. I would think the 8ba is similar.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 03-05-2012, 10:53 AM   #10
Old Henry
Old Henry's Avatar
The movement of air past that vent actually creates a vacuum that draws the air out of that vent, thus creating the draft from the oil filler cap through the engine as in my illustration.
Old 03-05-2012, 10:56 AM   #11
ken ct
It goes in[air] at the top and exits at the front bottom of the oil pan or the road draft tube.I thought i explained that to you on the phone.You need the road draft tube to make that work right. He has the wrong yr manifold on a later engine.Early manifold on a late engine. ken ct.Evidently he dosn't understand what hes got there. The air flow will not go in the same hole and come out the same hole.
ken ct is offline   Reply With Quote
Old 03-05-2012, 12:44 PM   #12
Jack E/NJ
Jack E/NJ's Avatar
Well, Old Henry, some of us figured Old Henry Ford had it all bassackwards and this is the sorta of the way some of us do positive crankcase ventilation now. But I'm not naming names. 8^) Jack E/NJ
Old 03-05-2012, 12:49 PM   #13
Old Henry
Old Henry's Avatar
The problem with running it backwards like that is that you have nothing filtering the air that's going in at the bottom so you can suck in anything that's being kicked up by the front right tire that's right there - dirt, dust, mud, water. Not good. That's why there's a filter on the oil filler cap that has to be cleaned every 1,000 miles - 'cause that's where the air goes in, not where it comes out.
Old 03-05-2012, 12:57 PM   #14
Jack E/NJ
Jack E/NJ's Avatar
Note that there's an inlet air filter wrapped around the body of the crankcase vent.
Jack E/NJ
Old 03-05-2012, 01:01 PM   #15
Jack E/NJ
Jack E/NJ's Avatar
Note also, the crankcase filler cap is a Chrysler PCV style filled with stainless steel mesh to prevent backfire into the crankcase.
Jack E/NJ
Old 03-05-2012, 01:33 PM   #16
flatjack9
flatjack9's Avatar
Note that your diagram does not show any of those items clearly.
Old 03-05-2012, 01:45 PM   #17
Shadetree
Shadetree's Avatar
Wouldn't be simpler to find the correct intake manifold and breather pipe for an 8BA?
Shadetree
Old 03-05-2012, 02:06 PM   #18
ken ct
Smile Re: Ventilating the Flat Head!
Shadetree
Yea but i think hes running a 2 pot manifold,i suggested try making a swap with some one. ken ct.
Old 03-05-2012, 02:13 PM   #19
Shadetree
Shadetree's Avatar
Ah so!
Shadetree
Old 03-05-2012, 02:42 PM   #20
Jack E/NJ
Jack E/NJ's Avatar
Flatjack9>>>Note that your diagram does not show any of those items clearly.>>>
Sorry diagram was not so clear on oil breather cap, image shown below. The vent filter is simply a fine mesh screen wrapped around and secured to the vent body(I'm using a stainless steel coffee filter screen from WalMart). You can even use fiberglas or aluminum window screen material wrapped a few times around the vent. Hard to show all this in Old Henry's diagram --- it was hard enough reversing all the airflow arrows so they all pointed in the right direction. 8^)
Jack E/NJ
