Old 04-24-2018, 07:17 PM   #1
Randall
Randall's Avatar
Default 40 Ford gas gauge problem
Hey fellows working on a 40 Ford someone has installed a new gas sending unit,sometimes it will work and sometimes it pegs the needle like it’s grounded,thought it was wire going to sender,but ran a new wire and it’s doing the same thing,voltage going into gauge is 6v and going to sender is 4.5 v,any you fellas had any problems like this?thanks
Randall is offline   Reply With Quote
Old 04-24-2018, 07:31 PM   #2
JSeery
JSeery's Avatar
Default Re: 40 Ford gas gauge problem
Those replacement gauges can be all kinds of trouble.
Old 04-24-2018, 08:15 PM   #3
Randall
Randall's Avatar
Im sure they can be ,but its doing it with the sending unit unhooked.
Old 04-24-2018, 08:18 PM   #4
JSeery
JSeery's Avatar
You can test the gauge side using small batteries of different voltages to see what it reads. A D cell battery (1.5 v) should get the gauge to read around 1/2 mark. Here are some past post if your interested.
https://www.fordbarn.com/forum/showt...ing+fuel+gauge
Old 04-24-2018, 08:33 PM   #5
Randall
Randall's Avatar
its strange that even without it hooked up it pegs the gauge sometimes and sometime it don't thats why I ran a new wire,thought it was broke and grounded out,when I was trouble shooting it I grounded wire and gauge did nothing,ran the new wire it worked then drove less than a mile and it peged gauge.
Old 04-24-2018, 08:35 PM   #6
JSeery
JSeery's Avatar
Might be something on the gauge itself that is grounding out. Believe that is just cardboard on the back that provides the insulation.
Old 04-24-2018, 08:44 PM   #7
Randall
Randall's Avatar
Thanks jseery i'll check it tomorrow
Old 04-26-2018, 02:05 PM   #8
Randall
Randall's Avatar
Jseery , didn't see anything wrong on the back side ,but hooked wire back on and it's working fine now ,mabe I moved something that was causing the problem,
