06-06-2019, 07:04 PM | #1 |
Parking light ground wire
I recently installed a new wiring hardness in my 68B Cabriolet and at the same time upgraded the head lights to LED and installed new headlight reflectors. The new reflectors are from Brattons and the reflector has a black finish on the back which is not conductive like the old reflectors were so I lost the ground to the Parking Light socket. I ran a new ground wire and flattened the wire to pinch it between the socket and reflector in order to ground the socket. Does anyone have a better way to ground the socket? My car is 12 volt, negative ground.
06-06-2019, 10:46 PM | #2 |
Re: Parking light ground wire
How about a dab of solder bond? Are the reflectors metal?
06-07-2019, 10:24 AM | #3 |
I'm really surprised (and disappointed) Bratton's reflectors are nonconductive. The grounding path relies on the connection between the reflector and the steel mounting ring in the bucket.
This might be more reliable - attach a wire between the socket sleeve(s) and the conduit socket holder with small hose clamps. Tin the wire ends with solder so the connections don't corrode. |
06-07-2019, 10:59 AM | #4 |
Bratton's reflector should conduct electricity. It is made of aluminum.
06-08-2019, 10:02 AM | #5 |
06-08-2019, 10:28 AM | #6 |
Bob |
06-08-2019, 03:01 PM | #7 |
You're 12V and LED's, so not original, run a separate ground wire back thru the conduit and ground it to frame near front fender. FWIW
Paul in CT |
06-08-2019, 05:16 PM | #8 |
06-08-2019, 05:47 PM | #9 |
Unfortunately what you have done is the simplest way to effect a ground. I do it myself and i hate it.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
06-10-2019, 06:57 PM | #10 |
I ended up crimping an eye lug on the wire and then inserting the wire terminal between the reflector and the socket then I put a small hoes clamp around the socket and tightened the clamp so I can not pull it out - this worked very well - thanks for the idea.
06-10-2019, 09:35 PM | #11 |
Would that not have been easier just soldering it?
06-12-2019, 07:00 PM | #12 |
I tried to solder to the socket and it would not stick to it - possibly my soldering iron is not hot enough. I even tried using soldering paste but it did work. The hose clamp works very well.
