Old 05-05-2018, 12:34 PM   #1
Great Lakes Greg
Great Lakes Greg's Avatar
Default Found a short, here is what it was...
My car stopped running three times this morning, each time blowing the fuse. After extensive wiggling, probing and checking, I found my metal conduit tube shorting against a flag terminal end in the junction box. I have heard of this before, just never experienced it. I thought I would pass it along in the event a mysterious short happens with your own car.
Great Lakes Greg is offline   Reply With Quote
Old 05-06-2018, 09:07 AM   #2
Badpuppy
Default Re: Found a short, here is what it was...
Must be missing the conduit grommet, same one as the battery cable clamp grommet.
Old 05-06-2018, 09:19 AM   #3
Jim/GA
Jim/GA's Avatar
No, he's talking about the metal pipe that runs from terminal box to generator, along firewall and side of engine. If pushed too far in, it will short out. No grommet there. (Grommet on ignition cable.)
Jim Cannon
"Have a Model A day!"
Old 05-06-2018, 10:07 AM   #4
midgetracer
midgetracer's Avatar
Not one of Henry's best ideas. i had the same problem and nearly burned up a fresh restoration.
midgetracer is offline   Reply With Quote
Old 05-06-2018, 11:25 AM   #5
Growley bear
The Ford service bulletins page 423--Feb. 1930 state: New Terminal Block To
Generator Conduit. The metal sometimes cracked or broke. So to eliminate that condition the metal was changed to a pliable black lacquered loom.
No mention of electrical short circuits occurring but one has to wonder.
Growley bear is offline   Reply With Quote
Old 05-06-2018, 01:05 PM   #6
GPierce
GPierce's Avatar
My Brattons wiring harness came with that pliable black loom from the junction box to the generator.
GPierce is offline   Reply With Quote
Old 05-07-2018, 04:19 PM   #7
Badpuppy
Forgot the early ones were metal. (Now I get it.) I would wrap the end with friction tape to insulate it, if you want to keep it strictly original. (They had friction tape back then.)
Old 05-08-2018, 06:56 AM   #8
chap52
chap52's Avatar
Yeah but it was the cloth type, not the plastic stuff you get today.
Old 05-08-2018, 07:49 AM   #9
SeaSlugs
SeaSlugs's Avatar
They sell cloth friction tape - check in sporting goods stores - usually to wrap basebal bat handles, hockey stick handles, etc. Grippy and sticky as hell I have a roll that is rather useful to have around.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-08-2018, 08:35 AM   #10
FRANK PKNY
FRANK PKNY's Avatar
HOME DEPOT CARRIES IT IN THE ELECTRICAL SECTION. I use it a lot on old style electrical wiring. Good stuff.
FRANK PKNY is offline   Reply With Quote
Old 05-08-2018, 09:55 AM   #11
ericr
ericr's Avatar
it is such a tight fit within that box, I wish it had been made slightly wider.
ericr is offline   Reply With Quote
Old 05-08-2018, 10:50 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
Paint the end of the conduit with a few coats of POR-15, and it will not short again even if it touches the terminal stud.
Bob Bidonde
Old 05-08-2018, 11:45 AM   #13
Badpuppy
Got a roll at WalMart last month, buck and a half or so.
