Old 02-15-2019, 01:43 PM   #1
Burgamot
Default emergency radiator repair
on a recent episode of gold rush they had a leak devloped in the radiator of a d-8 cat. with no repair facility close the mechanic put eggs(number?) in the radiator and the leak stopped. this reminded me of a call to the radio show on pbs called car talk. there a caller related being in a rural area when his radiator started leaking and a freind suggested putting eggs in the radiator which he did. the leak stopped was able to drive home and where it did leak again he drove it for a year when he sold it. interesting.
Burgamot is offline   Reply With Quote
Old 02-15-2019, 03:46 PM   #2
wmws
Default Re: emergency radiator repair
I assume you crack the egg open first. I've heard of oatmeal but not eggs.
wmws is offline   Reply With Quote
Old 02-15-2019, 03:51 PM   #3
Ruth
Old Timer told me black pepper. Didn't say how much or why only black pepper/
Old 02-15-2019, 04:17 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
I used black pepper in my September 29 in the early 60s , it worked pretty good . When the 4 blade fan slung a blade and cut a few tubes , I pinched them shut with pliers . They use to say you could block off six tubes and still get by . The car now has a nearly new aluminum radiator and I don't have to worry with it like I did many years ago .
Old 02-15-2019, 04:59 PM   #5
Synchro909
Synchro909's Avatar
Eggs, pepper, oatmeal, dry manure are all old time fixes. I remember my grandfather telling me about them.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-15-2019, 05:01 PM   #6
Dodge
Isn’t it the egg white only?
Dodge is offline   Reply With Quote
Old 02-15-2019, 05:07 PM   #7
F.M.
I always carried a one pound box of pepper while driving around Da-Nang in 1965, had no other fix.. When I left Country it was still going. Oh, A Jeep.. Might have tried Eggs, but all we had was C-Rations !!
F.M. is offline   Reply With Quote
Old 02-15-2019, 06:49 PM   #8
29leatherbackA
My grandpa had an A when he was a teenager and used the egg method. I had a leaky radiatior and he just cracked an egg in it and it quit leaking. One whole egg, he said you could throw another one in if it still leaked.
29leatherbackA is offline   Reply With Quote
Old 02-15-2019, 07:25 PM   #9
GPierce
GPierce's Avatar
He cracked two eggs open and dropped the contents, yolk and white, in the D8 Cat radiator.
GPierce is offline   Reply With Quote
Old 02-15-2019, 11:16 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
That's the same 4 things I heard of for an emergency fix, and I always wondered if they really worked.
My 28 Phaeton still has the original radiator, and when I bought the car in 1999 it had a damp spot near the top right of the radiator core. I put some stop leak in, and it's been bone dry ever since. It even held up fine after using vinegar for a month as a rust remover and cleaner.
Old 02-16-2019, 07:53 AM   #11
chap52
chap52's Avatar
What, powdered eggs wouldn't work? How about some of that delicious powered milk? Or the grape flavored "bug juice"?
Thanks for your service, Chap
chap52 is offline   Reply With Quote
Old 02-16-2019, 09:11 AM   #12
Ray64
Ray64's Avatar
I used a lot of black pepper in my younger days swear by it
Ray64 is offline   Reply With Quote
Old 02-16-2019, 09:31 AM   #13
eagle
eagle's Avatar
Another trick my granpa told me about. Burn some cork, then put the ash in the oil to reduce blue smoke out the tailpipe due to bad rings.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 02-16-2019, 01:25 PM   #14
1931 flamingo
1931 flamingo's Avatar
Banannana peels in the differential................................
Paul in CT
Old 02-16-2019, 05:15 PM   #15
Tom Wesenberg
Never heard of that one before. That's what STP is for. LOL
I used lots of STP in my 54 Chevy during my senior year in high school. One piston had a bad ring land and a broken ring. Even though I replaced that piston's rings, one broke again real soon due to the bad ring land.
Old 02-16-2019, 11:21 PM   #16
redmodelt
redmodelt's Avatar
I would suggest Water Glass (sodium silicate) but it says right on the package not to use with anti-freeze. All the years I have read about using it, never knew and was never talked about!
Old 02-16-2019, 11:57 PM   #17
Purdy Swoft
I have used water glass . The instructions said to use water glass with water . Let the engine run for a specified length of time and drain it . After that you can use water with antifreeze . You are just not suppose to mix water glass with antifreeze and run it that way . I have had good luck with water glass .
Old 02-18-2019, 01:12 PM   #18
Jim Brierley
I used STP in the leaky shocks in my '54 Olds, sure stiffened the up, and stayed in longer than the "correct" fluid!
Jim Brierley is offline   Reply With Quote
Old 02-19-2019, 08:22 AM   #19
Cave
Cave's Avatar
"Smoke 'em if ya got 'em" --- back in the C Ration days cigarettes were packed with the meals, we were told if our Jeep radiator was leaking in the field to shred cigs into it. Don't know if it would have worked, never needed to find out.
Cave Luther
Syracuse, NY
1931 Deluxe Coupe (Rose)
______________________________________
"... I'm pullin' for ya, we're all in this together." Red Green
Cave is offline   Reply With Quote
Old 02-19-2019, 08:37 AM   #20
77Birdman
Ive heard of the egg trick, but none of the rest. Interesting.
77Birdman is offline   Reply With Quote
