03-02-2018, 09:45 AM | #1 |
Oil on radiator??
We just bought this 31 A coupe and noticed the oil at the lower end of the radiator. It doesn't appear that there's any oil leaks up front to cause this. Has anyone experienced this before?
Darol |
03-02-2018, 10:01 AM | #2 |
Re: Oil on radiator??
And your SURE its oil? Coolant leaks get sticky with time and can seem like oil.
Theres no logical reason i can think of why that big of an oil leak would show up there short of someone accidently knocking over an oil bottle.
03-02-2018, 10:04 AM | #3 |
Wash it off w/detergent and see if it re-appears.
03-02-2018, 10:16 AM | #4 |
Probably not oil but water with antifreeze.
03-02-2018, 10:19 AM | #5 |
If someone has over greased the rear water pump zerk the oil from the grease plus coolant can cause this. I have seen so many radiators that are full of grease from this. The rear pump zerk should get just a little grease maybe once a year. Open the cap and you may find that the extra grease will accumulate around the filler neck and the overflow.
Oklahoma City Model A Restorers Group. Last edited by TinCup; 03-02-2018 at 10:44 AM. |
03-02-2018, 10:21 AM | #6 |
03-02-2018, 10:22 AM | #7 |
Katy,
Spray 409 or Fantastic on a wide paint brush & run the bristles across through the fins & it cleans it nice & easy. No hosing needed. Bill W.
03-02-2018, 10:26 AM | #8 |
That was our thinking, but having never owned one of these before, I decided to ask you guys. I'll take a good look at the rear zerk/grease also and see if it's contributing. Thanks you guys!!
Darol |
03-02-2018, 10:39 AM | #9 | |
I've got Fantastic and will give it a try. Thanks!!
Darol |
03-02-2018, 10:53 AM | #10 |
03-02-2018, 11:42 AM | #11 |
oooh good point. about the right height for that. Does your wisdom come from experience?
03-02-2018, 12:27 PM | #12 |
Yes, Some things we learn the hard way, LOL!
03-02-2018, 05:19 PM | #13 | |
Bill W. & Buster T.
03-02-2018, 05:51 PM | #14 |
03-03-2018, 02:09 AM | #15 | |
Yep, it happened to me once, and I'd bet that's what happened here. When I bought my 28, it had a wet spot on the top right of the radiator. I used a radiator sealant like Bars Leak or something like that, and it's been dry for the past 18 years. |
03-03-2018, 09:46 AM | #16 |
Sometimes stains like that come from Folks that use Soluable Oil for a rust inhibitor & "maybe" it boiled over at one time. Seems that stains like that are fairly common.
I've even seen CARS for SALE, with stains like that. I've also seen them, with PUDDLES under them!!!! Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 03-03-2018 at 08:16 PM. |
03-04-2018, 07:05 PM | #17 |
Could be..... someone added soluble oil to radiator water instead of antifreeze. This is what in the old days was called water pump lubricant.
