05-09-2013, 05:08 PM | #1 |
Thermostat -= Yes or No
I just had my radiator rodded out and I plan on replacing both the hoses. my question-should I continue run a thermostat. I have one in my old hose now, but sometimes it over heats on hills? Not many hills here in Florida, but last year in Tennessee, it was a little hilly.
05-09-2013, 05:22 PM | #2 |
Re: Thermostat -= Yes or No
You know here in Oklahoma I run one during the winter months just to help bring the car up to temp. If I don't the car never runs over 140 and sometimes when it is really cold not even that. It causes for unburned condensation to build up. I can't see where you would need one in FL.
Oklahoma City Model A Restorers Group. |
05-09-2013, 05:31 PM | #3 |
yes
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
05-09-2013, 05:40 PM | #4 |
yes
05-09-2013, 05:41 PM | #5 |
There must have been a reason you had it rodded out, yes? Overheating? The t/stat, unless stuck had nothing to do with the overheating, as the others have said, re-install it. JMO
Paul in CT |
05-09-2013, 05:54 PM | #6 |
05-09-2013, 06:03 PM | #7 |
yes
05-09-2013, 06:04 PM | #8 |
Yes (40 miles from Ocala)
Ed LAW OF MECHANICAL REPAIR ONCE YOUR HANDS BECOME COVERED WITH GREASE,
YOUR NOSE WILL ITCH AND YOU'LL HAVE TO PEE |
05-09-2013, 06:18 PM | #9 |
Yes, Cocoa, Fl. You don't need one but the engine runs better with it.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
05-09-2013, 07:20 PM | #10 |
Yes!!!
A thermostat allows the engine to heat up to operating temperature faster, and keeps the engine at a more constant temperature!!
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
05-09-2013, 07:30 PM | #11 |
Thanks everyone, I'll put in a new one.
05-09-2013, 08:03 PM | #12 |
Make sure that it has a 1/8 inch bypass hole drilled in the flange, so there is enough flow to allow the stat to sense the coolant temp and to prevent localized hot spotting in the head during warmup.
Some of us drill two bypass holes, just to be sure. Slows warmup somewhat but if you've ever seen explosive vaporization, you won't mind. Steve |
05-09-2013, 08:07 PM | #13 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
05-09-2013, 10:07 PM | #14 |
05-10-2013, 12:02 AM | #15 | |
Cowtown A's |
05-10-2013, 12:48 PM | #16 |
I ran one in my Cabriolet one Winter, and it was great on drive ability and warm up.
The first hot South Georgia day, the temp gauge rose alarmingly, so I pulled it out, no more problems. Mine does have the bypass hole, and perhaps it didn't open correctly, but in this heat and humidity (and Stone Guard) I'd rather rely on more water flowing unimpeded. With Global Warming, I doubt I'll ever put it back in.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
