Old 07-14-2014, 02:13 PM   #1
Kennedy
Kennedy's Avatar
Default 1957 Ford frame
Can anyone tell me where the 2" difference is in a 116" and a 118" wheel base 57 Ford frame? I'm needing a new frame for my 116" wheel base 57 Ranch Wagon and all I can find is 118" wheel base frames.
Also, I have also been told that a 116" wheel base 56 Ford frame is the same as a 57 except for the body mount location. Does anyone know if there is any truth to that?
Thank You
Kennedy
Kennedy is offline   Reply With Quote
Old 07-14-2014, 03:30 PM   #2
Ford blue blood
Ford blue blood's Avatar
Default Re: 1957 Ford frame
Can't answer that but it seams like it would be in the area between the front and rear wheels under the body.
There is a fellow on the 57Fordsforever web site that had a Ranchero from to give away. His screen name is BWhitmore.
Try this link http://57fordsforever.com/smf/index.php?topic=4128.0
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 07-14-2014, 03:59 PM   #3
Oldmics
Comparing the 56 to the 57 frame specifically and only for the station wagon and courier (which are the same) which would be correct for your Ranchero, there are a lot of differences.
To cut to the chase a 56 frame wont work and only a station wagon/courier from a 57 donor will work for your replacement needs.
There is a 5" difference in the frame length between the 116" wheelbase and the 118" wheelbase vehicles on the 57 vehicles.
Oldmics
Oldmics is offline   Reply With Quote
Old 07-14-2014, 05:03 PM   #4
oj
[QUOTE=Ford blue blood;910148]Can't answer that but it seams like it would be in the area between the front and rear wheels under the body.
Woot! that made my day, I've been doing suspensions this afternoon and a coilover spring just whizzed past my ear. The above just put a smile on my face, thanks.
oj is offline   Reply With Quote
Old 07-15-2014, 09:35 AM   #5
Kennedy
Kennedy's Avatar
Thanks for all the info.
Old 07-15-2014, 11:20 AM   #6
JeffB2
JeffB2's Avatar
We have had guys swap front clips in my 1952-59 Ford Group with the 1952-55 Mercs the difference is usually behind the front seat in the rear seating area to allow for additional leg room in the premium models.
JeffB2 is offline   Reply With Quote
Old 07-31-2014, 11:13 AM   #7
cmintsurfer
cmintsurfer's Avatar
Kennedy, when you say "all I can find are 118" wheel base frames" are you referring to 1989 and older Lincoln Town car frames that have a similar shape as the original Ford frame under the 57? I have a project that is holding on the same decision. My 57 Ranchero frame was cut just behind the rear window and removed before I bought it.
cmintsurfer is offline   Reply With Quote
Old 07-31-2014, 02:33 PM   #8
cmintsurfer
My mistake. The 57 500 is the 118" frame you are referring to. I don't know the answer
Old 08-02-2014, 02:40 PM   #9
Rowdy
Would the frame from this one be the correct wheel base? Rod
Rowdy is offline   Reply With Quote
Old 08-02-2014, 04:45 PM   #10
Ford blue blood
Nope, that is a 500 and it is 118".
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
Old 08-02-2014, 11:13 PM   #11
Frankenstein57
Frankenstein57's Avatar
The rancheros were built on a wagon platform, the difference is in the crossmember over the rear end. This could be altered. I have two ranchero frames, a solid Vegas car and an Indiana frame, Mark
Frankenstein57 is offline   Reply With Quote
