Old 10-16-2013, 07:45 AM   #1
metalho
metalho's Avatar
Default ignition keeps cutting out
Something in the dash is making my ignition cut out. It runs fine until I lift the dash up to bolt it in, and before I even get it in place it cuts out, Im goin nuts!
metalho is offline   Reply With Quote
Old 10-16-2013, 08:02 AM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: ignition keeps cutting out
Sounds like the wire to the coil is shorting out on the tank some where.
Farrell In Vancouver is offline   Reply With Quote
Old 10-16-2013, 08:14 AM   #3
Mitch//pa
are the switch terminals touching the tank?
Old 10-16-2013, 08:15 AM   #4
H. L. Chauvin
A Wal-Mart Multi-meter with needle, (GE yellow model under $15.00), can save many hours of guessing to check electrical continuity in wires.
If your problem is the switch, in the pop-out switch area, Bratton's catalog indicates a diagram of how to test correct switch continuity with a multi-meter.
Many old wires in the switch's armored cable short out.
Metal wire connectors sometimes ground out on the inside of the gas tank.
Many install electrical tape on the inside of the gas tank to prevent shorts.
Again, a simple multi-meter can save many hours of guess work.
H. L. Chauvin is offline   Reply With Quote
Old 10-16-2013, 08:22 AM   #5
JBill
Try wrapping a little electrical tape around the ignition switch poles. They're probably contacting the gas tank.
JBill is offline   Reply With Quote
Old 10-16-2013, 08:33 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I had to bend the terminals to the side so they wouldn't short on the tank. On another repro switch I had to pry away the bent potmetal so I could remove the back and improve the contacts. With the switch in the ON position, the slightest touch of the key would make the contacts not touch.
As far as touching the tank, tape might wear through, and that would be bad if it happened in an intersection, or in the middle of the night. Better be safe and make sure there is clearance.
Old 10-16-2013, 02:03 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I glue a leather patch on the gas tank, right behind the ignition switch, also one on the back of the junction block. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-16-2013, 04:19 PM   #8
TDO
TDO's Avatar
This is where you need a fuse , The one that mounts on the starter
TDO is offline   Reply With Quote
Old 10-16-2013, 04:36 PM   #9
Cockshutt Kid
I had the same problem, and it nearly drove me crazy. It turned out to be a #^&!# reproduction dash panel. The hole for the pop out ignition switch was deformed and would jamb the switch causing it to not make contact. It worked and tested perfectly on the bench but sometimes worked in the car. A very large tapered punch and a deep socket adjusted it temporarily. I just got a good original today, so another job on the list for winter.
Cockshutt Kid is offline   Reply With Quote
Old 10-16-2013, 07:21 PM   #10
Tom Wesenberg
Since the switch and wire is on the ground side of the coil, the fuse won't blow with a short.
Old 10-21-2013, 07:53 AM   #11
metalho
metalho's Avatar
Combination of the ammeter, keyed ignition, stuck cut-off switch AND GREMLINS! Also timed the truck while we were at it. She's runnin fantastic now, AND I've learned a lot in the process but my God what a pain in the ass lol..............
Old 10-21-2013, 06:13 PM   #12
1931 flamingo
1931 flamingo's Avatar
IMO the are behind the dash was not one of Henry's brightest ideas. Wires are large and not flexible, replacement ign sw's not made correctly (if you can't afford a pop out), short posts on the ammeters (especially if adding a dash lamp) and tight, tight, tight when trying to tilt back to install. JMO
Paul in CT
Congrats on sticking with it and finding the fix ! ! !
Old 10-21-2013, 06:20 PM   #13
Skrain
Skrain's Avatar
All part of the fun of an 85 year old car!!
"They can make me grow older, but they CAN'T make me grow up!"
Skrain is offline   Reply With Quote
Old 10-21-2013, 07:16 PM   #14
Joe K
Joe K's Avatar
I especially like the repop terminal box (black plastic in center of firewall) with the threaded posts protruding or turning out the back of the box so they eventually wear a hole in the paint on the firewall and short out the system.
Talk about doomed to failure! (original boxes are insulated/covered at this location.)
And this one that might take you DAYS to find with a meter since it's not apparent at all.
Joe K
Shudda kept the horse.
Old 10-21-2013, 07:24 PM   #15
green30coupe
green30coupe's Avatar
Way to stick with it! If it was easy and cheap.....everybody would have one!
Ed
LAW OF MECHANICAL REPAIR
ONCE YOUR HANDS BECOME COVERED WITH GREASE,
YOUR NOSE WILL ITCH AND YOU'LL HAVE TO PEE
green30coupe is offline   Reply With Quote
