10-10-2017, 11:41 AM | #1 |
brake light switch
The vendors sell brake light switches at approx. $50 (USA made) and $6.
Has anyone noted a difference in operation / performance between them and mating to the brake pedal rod ? |
10-10-2017, 12:20 PM | #2 |
Re: brake light switch
If someone went out of their way to retool, find a place willing to make them, research blueprint specs, find materials suitable, and have them made theres a very good reason. Do you REALLY want a flaky brake light switch? Its a safety item for you your passengers and other motorists.
Now if someone could do the same for a quality ammeter...
1929 Model AA - Need long splash aprons! |
10-10-2017, 01:54 PM | #3 |
A & L makes a great switch, with a bronze bushing that will never stick.
10-10-2017, 07:29 PM | #4 |
Usually the switch isn't hard to fix.
10-10-2017, 09:14 PM | #5 |
Thanks Terry; is A&L still in business? I heard the owner passed away.
I'm curious whether the 10x cost justifies a comparison. |
10-10-2017, 09:19 PM | #6 |
10-11-2017, 11:15 AM | #7 |
A&L still going strong. His son took over the business. No web site BUT they do answer the phone.
Paul in CT |
10-11-2017, 03:40 PM | #8 |
The A&L switch is the best. Worth the money and you won't have problems with it. Case closed.
10-11-2017, 06:34 PM | #9 |
The $6.00 switch is junk. I through the one I bought away and got the better switch. I still had to do some work to make it work well.
10-11-2017, 08:29 PM | #10 |
The cheap switch I bought would stick leaving my brake lights lit. Lithium grease helped, however I have the replacement in hand and it will be on before my next run around the block.
10-11-2017, 09:04 PM | #11 |
10-11-2017, 11:00 PM | #12 |
Will try A&L again, no answer. I forgot to ask how much is their brake switch?
10-12-2017, 02:32 AM | #13 |
I don't remember the cost, as I bought mine over 10 years ago, after our Tom Endy suggested buying from A&L. It has a pre-lubricated bronze bushing, which the others don't. Usually the best is worth paying more for....
