10-10-2017, 11:35 AM | #1 |
differential questions
when adjusting both the carrier and pinion preload according to Les Andrews, do you put the carrier assy together dry? or do you lube it? same with the pinion bearing.
thanks |
10-10-2017, 12:24 PM | #2 |
Re: differential questions
I don't put it in dry. Les' method is just one of many good ways, but the bottom line is you just need a little preload to compensate for when the bearing wears after a bit of use. Common sense should prevail in this.
10-10-2017, 01:00 PM | #3 |
Thanks
10-11-2017, 10:23 AM | #4 |
