06-19-2017, 08:30 AM | #21 |
Re: Knock, knock, knock sound
"POSSIBLY" loose flywheel bolts??? Pry on flywheel teeth & see if flywheel rotates back & forth about 1/8 Inch.
Bill Loose
06-19-2017, 08:35 AM | #22 |
i would pull the pan , not run it more . check exhaust for leak . could a piston be hitting a valve or the head ? .............. good luck .
V4f |
06-19-2017, 08:42 AM | #23 |
With engine turn off pry gently on the crank pulley to see if moves back and forth
06-19-2017, 08:43 AM | #24 |
Please let us know what you find.
06-19-2017, 09:29 AM | #25 | |
06-19-2017, 09:29 AM | #26 |
To me when some one says rebuilt I get real worried. |
06-19-2017, 01:17 PM | #27 |
I recently developed a knock on the 31 AA, fearing the center main was gone I started with the simple first. Pulled the belt still knocked. Checked with a stethoscope and found the noise throbbing in around the cam gear. Pulled the side cover a found the cam gear real loose, like a half inch wobble. This engine still ran!? Pulled the front cover and inspected the plunger and spring, all good there. Took the cam nut off the last four threads and washed the nut and cam off with Brake clean. Air dried them up and applied a little Blue Loc-tite. Screwed it back on and tightened it up. I hand cranked it over to find no missing or ruined teeth, so I just buttoned her up and took it for a lap. She's happy again!
06-19-2017, 01:28 PM | #28 |
This also happened to me once but the knock came and went with changes in engine speed. It would also change timing as the cam moved back and forth in the block. I had to retime the car every few miles to keep it running and later discovered the broken cam plunger spring as the culprit.
06-19-2017, 01:35 PM | #29 |
SINCE IT WAS JUST REBUILT.
I wonder if the Dipper tray pan has popped loose and the rods are striking it! MAYBE dipper tray was loose and not snapped all of the way into the grooves. At least it sounds that way to me!! Last edited by Benson; 06-19-2017 at 03:58 PM. |
06-19-2017, 02:53 PM | #30 |
Sounds like first, or second rod to me.
Herm. |
06-19-2017, 03:02 PM | #31 |
I'm with the loose flywheel crowd
06-19-2017, 03:26 PM | #32 | |
https://vimeo.com/222254828 I guess Tomorrow the pan comes off as Im fearing the worst. As for rebuild. I was the one who basically took it all apart, cleaned everything and but her back together years ago in 2003. If it's time to do the ol girl right, it's time is now. Anyone want to come help? Michael |
06-19-2017, 03:42 PM | #33 |
The first video hurts to listen too.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
06-19-2017, 07:28 PM | #34 |
Hopefully all the rod scoops have the opening facing the camshaft.
Guess we'll learn more tomorrow. |
06-20-2017, 04:33 PM | #35 |
NOTE: A Model A piston can NOT hit a VALVE!
Bill Clearance
06-20-2017, 04:56 PM | #36 |
Our Vicky developed a similar sound. It is. Model A Engine with a Miller Overhead Valve Head.
The sound was more of a clicking sound, not a deep thud like a rod or main. I first thought it was the rockers not properly adjusted, that didn't work. Removed fan belt, no change, shorted out spark plugs, no change in the sound. I also used a stethoscope, but couldn't locate the source. It did seem noisier under the car, pan area. Lighter metal of the pan might have amplified the noise. I removed the engine, checking everything I could think of along the way. I found the problem to be a lose Timing Gear. The nut was backed off a couple of threads, and there was significant movement in all directions, as well as very worn. It was a fiber gear, being replaced with an aluminum gear. It is not back together yet, doing some other things while it is apart, but I'm sure this was the problem. |
06-20-2017, 05:32 PM | #37 |
06-20-2017, 06:43 PM | #38 |
I'm wondering how that engine ran with 2+ teeth missing.
Is that the clicking sound heard in the video? Is the broken cam gear "the issue" or is it a result of the issue?
All steel from pedal to wheel |
06-20-2017, 06:59 PM | #39 |
With a all of fiber inside oil pan ... Do Not forget to clean out the oil pump filter screen inside the "cover" of oil pump!
06-20-2017, 07:15 PM | #40 | |
Michael |
