Old 10-10-2017, 11:35 AM   #1
rer_239
rer_239's Avatar
Default differential questions
when adjusting both the carrier and pinion preload according to Les Andrews, do you put the carrier assy together dry? or do you lube it? same with the pinion bearing.
thanks
rer_239 is offline   Reply With Quote
Old 10-10-2017, 12:24 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: differential questions
I don't put it in dry. Les' method is just one of many good ways, but the bottom line is you just need a little preload to compensate for when the bearing wears after a bit of use. Common sense should prevail in this.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-10-2017, 01:00 PM   #3
rer_239
rer_239's Avatar
Thanks
Old 10-11-2017, 10:23 AM   #4
Jim Brierley
Use a little engine oil. Also don't tighten the side housings without gaskets, the housings will bend, then leak!
