Old 08-18-2017, 05:46 PM   #1
Minn-Tex Lee
Minn-Tex Lee's Avatar
Default Points
While checking my points I noticed that the stationary one had a round hole in it. Is this a normal condition?
Still learning
Lee
Minn-Tex Lee is offline   Reply With Quote
Old 08-18-2017, 06:15 PM   #2
Big hammer
Default Re: Points
Yes
get a bigger hammer tap done
Old 08-18-2017, 06:43 PM   #3
Minn-Tex Lee
Default Re: Points
Thank you
Lee
Old 08-19-2017, 05:56 AM   #4
Patrick L.
Patrick L.'s Avatar
Default Re: Points
Yep. Some do and some don't.
Old 08-19-2017, 10:08 AM   #5
katy
katy's Avatar
Default Re: Points
I goofed
Play it again Sam.
Old 08-19-2017, 11:41 AM   #6
mike657894
mike657894's Avatar
Default Re: Points
new points were part of a tune up. you may want to get a new set of points.
mike657894 is offline   Reply With Quote
Old 08-19-2017, 01:21 PM   #7
eagle
eagle's Avatar
Default Re: Points
If the points appear in good condition, I would clean them and adjust them, NOT replace. Some of the new ones aren't as good as the old.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 08-19-2017, 03:21 PM   #8
Kevin in NJ
Default Re: Points
You should only replace points when the point blocks are bad or the wear block is gone.
Getting 40 years on a set of used points is completely possible. It takes a very smooth cam and regular lubrication.
Cabriolet and Technical Hints
Kevin in NJ is offline   Reply With Quote
Old 08-19-2017, 04:05 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Points
The ones with the hole are less prone to making a PIT & a POTHOLE & last MUCH longer!
Bill Holeproponent
"THE ASSISTANT GURU OF STUFF"
Old 08-19-2017, 04:55 PM   #10
Synchro909
Synchro909's Avatar
Default Re: Points
Bill Holeproponent
You beat me to it, Bill.
If schools stay closed too long, parents will find a vaccine before the scientists.
Old 08-23-2017, 05:52 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Points
Ah yes, the donut points to go along with the donut manifold.
8 and 9 are right on, plus the hole makes the points stay cooler.
Thread Tools
Display Modes
