Old 06-10-2017, 01:52 PM   #1
Minn-Tex Lee
Minn-Tex Lee's Avatar
Default My miss is gone
For a year I have been fighting a severe miss. I went through all of the normal suggestions -testing pressure, soaking cylinders with various fluids, changing out the plugs, new coil etc. This year I was about to check for a broken valve spring.
I started the engine and sure enough it still missed for about 15 seconds and then it purred like a kitten. I took it for a 10 mile ride with no problem. My questions are these:
1) What do you think the problem was?
2) What are the chances the problem will return?
I was hoping to get a chance to use my new 4 trace 4 color scope to see if it was electrical but I guess that wont be necessary.
It did, by the way, go through a Minnesota freeze thaw cycle in an unheated garage.
Thanks for your thoughts
Lee
Minn-Tex Lee is offline   Reply With Quote
Old 06-10-2017, 01:56 PM   #2
ronn
Default Re: My miss is gone
keep your chin up- plenty of women out there.............!
Old 06-10-2017, 01:56 PM   #3
fastroadster
Stuck valve???
fastroadster is offline   Reply With Quote
Old 06-10-2017, 02:34 PM   #4
Patrick L.
Patrick L.'s Avatar
Originally Posted by fastroadster View Post
Stuck valve???
My thought too.
Old 06-10-2017, 03:40 PM   #5
Dollar Bill
Dollar Bill's Avatar
At a minimum, i recommend adding MMO or ATF to your fuel tank. Helps with sticky valves and it makes corn fuel more palatable.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 06-10-2017, 03:42 PM   #6
JOHN CT
JOHN CT's Avatar
Put 4 oz MMO in the gas tank and go for a ride. It wouldn't hurt.
I agree with a stuck valve
Dollar bill types faster than me
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 06-10-2017, 03:45 PM   #7
Big hammer
Sticking vavle, mmo in the gas tank and some in the oil should keep it running well !
get a bigger hammer tap done
Old 06-10-2017, 04:01 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with all the above, except #2.
A good woman is getting hard to find.
Old 06-10-2017, 04:02 PM   #9
H. L. Chauvin
Hi Lee,
Not much difference between a difficult problem with a Miss; and a difficult problem with a Model A ....
With your questions:
"1) What do you think the problem was?" and,
"2) What are the chances the problem will return?"
My guesses:
1) The Model A got fed up with the Miss; and,
2) No, she's not coming back!
H. L. Chauvin is offline   Reply With Quote
Old 06-10-2017, 06:12 PM   #10
captndan
captndan's Avatar
Originally Posted by H. L. Chauvin View Post
Hi Lee,
My guesses:
That really hurts!
captndan is offline   Reply With Quote
Old 06-10-2017, 06:54 PM   #11
Ed H.
Sounds like a vacuum leak to me. Once the eng got warm what ever was not sealing expanded to make a seal. I would replace the intake gasket, carefully look it over for signs of leakage.
If it was a valve it would make a ticking or a some sort of noise prior to coming loose.
My .02
If you see a bomb technician running, do everything in your power to keep up with him.
United States Navy
Ed H. is offline   Reply With Quote
Old 06-11-2017, 07:21 AM   #12
Growley bear
Not a good sign when they fix themselves.
Growley bear is offline   Reply With Quote
Old 06-11-2017, 03:52 PM   #13
Minn-Tex Lee
Thanks for all of the replays. I do not use corn base fuel, but none the less I will take the advise and start adding MMO to my fuel each time I fill up.
Lee
Old 06-12-2017, 08:08 AM   #14
ronn
for awhile, Model A's were tough to find at the right price and as of late, Im seeing some fantastic deals!
gotta know where to look.
Old 06-12-2017, 01:19 PM   #15
H. L. Chauvin
Per Ronn's Reply #14, appears lots of 28-31 Model A's are advertised on the market in the past few years.
Looks like we have more Model A's offered than that of interested Model A buyers.
Car collector/investor whom I bought my 1930 Town Sedan was disappointed that after paying for storage area for mine for 20 years, Model A prices did not increase that much; however, for his investment purchases, selling prices for his collection of later 50's - 60's cars went up considerably.
Old 06-12-2017, 02:35 PM   #16
c125bob
c125bob's Avatar
Good news !
Bob
1930 Tudor
Chattahoochee Hills, Ga
c125bob is offline   Reply With Quote
Old 06-12-2017, 05:20 PM   #17
H. L. Chauvin
Re: My miss is gone.
What was her name?
Old 06-13-2017, 11:20 AM   #18
Beater
Beater's Avatar
I think also a stuck / sticky valve. I also used to used MMO in the fuel every tankfull. for a sticky valve however ive had way better luck adding some good 2 cycle oil to the fuel
Beater is offline   Reply With Quote
Old 06-13-2017, 12:11 PM   #19
H. L. Chauvin
About the time of WWI, commercial fishermen learned that their (2) cycle hit and miss engines used every day in their small boats had far less top of cylinder wear because of adding oil to fuel ..... many car owners in these coastal areas also heard of this fact and started adding a little oil to fuel during Model T days and Model A days.
Adding vintage commercially available top cylinder lubricant or Marvel "Mystery" Oil, (MMO), never was a "mystery" for those few who understood how it worked to add lubrication to upper engine pure non-lubricating gasoline.
Old 06-13-2017, 07:44 PM   #20
Jerry in Shasta
Jerry in Shasta's Avatar
Damn I hate it when they heal them selves!
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
