01-29-2020, 08:14 PM | #1 |
Shell Oil Canister
Hi,
I have a glass Shell oil canister on the firewall of my A. It is plumbed into the intake manifold. I can't seem to find any info out there on it. My question is what is it for and do I need it? Thanks, Andrew |
01-29-2020, 08:39 PM | #2 |
Re: Shell Oil Canister
I’m thinking someone used it for a vacuum storage tank for a vacuum wipe wipe motor.That would keep the wipers going when under heavy engine loads and the vacuum normally drops off.Dont need it in my opinion. Dennis
01-29-2020, 09:08 PM | #3 |
If the pipe connecting it to the manifold has a valve in it, I'm guessing it was for an automatic feed for upper cylinder lubricant direct into the manifold. It was quite a common thing for years.
01-30-2020, 12:19 PM | #4 |
Do I need it?
01-29-2020, 09:00 PM | #5 |
Well I didn’t read your post close enough the first time and thought it was a metal canister.Maybe it’s some sort of water injector to help remove carbo from the combustion chambers.Just a guess.
01-30-2020, 01:20 PM | #6 |
Can you post a photo? Pluck |
01-30-2020, 04:16 PM | #7 |
None of the above guesses as to what it is are essential functions so you can safely remove it and block off the hole in the manifold.
02-01-2020, 02:44 PM | #8 |
I would be tempted to put some Marvel Mystery Oil in the jar and see what happens to how the car runs...There were lots of these systems made...this sounds like a home made one...might work nice! Many of us do run Marvel Mystery Oil one way or another. Ernie in Arizona
