Old 10-25-2017, 12:21 PM   #1
burner31
burner31's Avatar
Default Running board mats
Do the cheaper running board mats from MAC's and Mike's need to be cut to fit?
They look squared off in the pics while my boards are tapered ('31 town sedan)
Figure I'm still a few year from paint and can't see putting the high dollar ones on at this time.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 10-25-2017, 06:41 PM   #2
Brace Bailey
Brace Bailey's Avatar
Default Re: Running board mats
I just in-wrapped my roll of Vintaque running board material - and discovered that there are two mats already cut. They may be 1/8Ē too big, but Iím going to leave them out to see if they shrink. Right now they will almost lay flat on the boards.
Now the question is: what kind of adhesive can I use that will let me slide the mats under the zink edges? If I use contact cement, Iím sure I wonít be able to slide them under the edge. Any ideas?
Last edited by Brace Bailey; 10-27-2017 at 05:31 PM. Reason: I double checked - and they are pre-cut
Brace Bailey is offline   Reply With Quote
Old 10-25-2017, 06:50 PM   #3
WHN
Originally Posted by Brace Bailey View Post
I have a roll of running board mat - and it is square - will need to be trimmed. Iím going to paint the underneath side of the boards tomorrow- and Iím trying to decide weather or not to paint the edges. Most of the boards I see are a dull zink colored - and not painted black. Iím putting the car boards on my pickup. I got a pretty good deal on them, and I donít want to scratch up the truck type boards.
If you want it to look as from the factory, donít paint the edges. Dull zink is correct. Enjoy.
WHN is offline   Reply With Quote
Old 10-25-2017, 08:36 PM   #4
SteveB31
SteveB31's Avatar
There are a couple different manufacturers of these mats. Some are cut to fit, and some are not. Some have sticky backing on them and some do not. Neither of those are designed for 1931 runningboards- they are designed for 1930 runningboards that have zinc trim on all 4 sides. 1931 boards only have trim on the outer edge and use a different rubber that has the round edge on the inner, front and back edges.
1930
https://parts.modelastore.com/show_Product.asp?ID=4579
1931
https://parts.modelastore.com/show_Product.asp?ID=4581
Steve @ Bert's
SteveB31 is offline   Reply With Quote
Old 10-26-2017, 09:25 PM   #5
Brace Bailey
Painted the running boards today - left the Zink taped up so it will look like the factory.
Thanks for the note on that!
Old 10-27-2017, 05:33 PM   #6
Brace Bailey
See my note - edited above. My mats were pre-cut.
Wondering what kind of adheasive would stay slick enough to let me slide the mats under the zink lip - then set up and hold them down.
Old 10-27-2017, 09:35 PM   #7
marc silva
marc silva's Avatar
If you put them on before the contact fully dries (almost dry)they will move and eventually stick. Dry fit them first .
marc silva is offline   Reply With Quote
Old 10-28-2017, 08:59 AM   #8
Brace Bailey
Thanks... I’m still trying to decide if I should trim a bit (1/8”).....
Dry fit still leaves a bubble across the surface
Old 10-28-2017, 09:20 AM   #9
Larry Jenkins
I like your idea about setting them out in the Sun a couple days. Measure before and after. Then you will know if they shrunk. Look at different types of Contact cement.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 10-28-2017, 09:25 AM   #10
marc silva
marc silva's Avatar
Depending on how much "bubble" I would leave it to allow for a little shrink. The adhesive will hold it down. You may want to cut a piece of plywood the size of the running board and then stack some weight on it for a while to hold it flat.
Old 10-28-2017, 09:27 AM   #11
marc silva
marc silva's Avatar
Should have added while the adhesive dries.
Old 10-28-2017, 09:46 AM   #12
Dino's A
My running board material is 20 years old but car was in storage so no wear to them but, is there anything special to use to make them look new? I've tried everything from Armor all to 303 protectant. Don't want a shine but a uniform matte finish as they were newer.
Dino's A is offline   Reply With Quote
Old 10-28-2017, 09:56 AM   #13
burner31
burner31's Avatar
Bleach/white tire cleaner, sit for one minute, scrub, rinse well with clean water
But stay away from the paint as much as possible
Keith
Shawnee OK
'31 SW 160-B
Old 10-28-2017, 10:33 AM   #14
Dino's A
Thanks! I never thought of trying that. Thank You.
Dino Falabrino
Old 10-28-2017, 11:23 PM   #15
marc silva
marc silva's Avatar
You may want to try some lacquer thinner on a rag. Just be careful not to the paint.
Thread Tools
Display Modes
