05-05-2019, 09:36 PM | #1 |
No start
Engine cranks but doesn't fire until I release the starter. 6 volt pos. Ground.
Sent from my SM-J701M using Tapatalk |
05-05-2019, 09:47 PM | #2 |
Re: No start
Put a ground strap between engine and frame. Check point gap.
05-05-2019, 09:53 PM | #3 | |
Re: No start
A defective battery will not provide enough voltage to run the ignition and the starter. Once the starter is off the voltage goes up and the coil fires before the engine stops turning over. Clip a meter to one of the nuts on the terminal block and measure the voltage with and without the starter running, should be only a small amount of difference.
05-05-2019, 10:28 PM | #4 |
Re: No start
Did you modify the wiring by adding a resister that is bypassed when starting? If the answer is yes check the resister and the connections to it.
Charlie Stephens |
05-05-2019, 11:24 PM | #5 |
Re: No start
No sir I did not. However my battery shut off is on the firewall and all the electrics is on the starter side of the switch. I realize it should be on the ground cable but it was that way when I got the car
05-06-2019, 07:37 AM | #6 |
Re: No start
05-06-2019, 08:32 AM | #7 |
Re: No start
I second the weak ground theory
05-06-2019, 08:45 AM | #8 |
Re: No start
It could also be the battery shut off switch is deteriorating.
John
As Carroll Smith wrote; All Failures are Human in Origin. |
05-06-2019, 08:52 AM | #9 |
Re: No start
Do you have modern wireless distributor plates? I had the wireless Nurex plates, sometimes was hard to start amongst other symptoms. Finally replaced with original design plates and all issues were solved.
05-07-2019, 07:23 AM | #10 |
Re: No start
