01-18-2019, 11:27 AM | #1 |
Rear Motor Mount Safety Wire
Pictures of original safety wire. It is from a rusty '30 Tudor that the odometer showed 30,000 miles.
01-18-2019, 12:19 PM | #2 |
Re: Rear Motor Mount Safety Wire
interesting
01-18-2019, 02:04 PM | #3 |
Yes, I have had several unmolested original A's come thru my shop with the same method of safety wiring. Below is a picture of the late Dave Lopes' Fordor that is touted as the best unrestored original Model-A know to exist. The wiring matches your picture John.
01-18-2019, 02:18 PM | #4 |
During my Navy enlistment, I worked on ejection seats/egress systems, that required safety wire on several system components. My QA (Quality Assurance) Inspector would look at a job I had done, count proper turns, direction and over-all appearance, and if not correct, would snip it off and tell me to do it over... when I did my motor mounts his words echoed as I made each turn.!
01-18-2019, 05:57 PM | #5 |
Worked in the o/haul shop at P&WA, interesting when two guys wiring on the same flange (100+ bolts) and one miscounts and it all has to be redone (wiring 2 bolts together, then 2 more, etc.
Paul in CT |
01-18-2019, 06:02 PM | #6 |
01-18-2019, 09:21 PM | #7 |
I try to add a twist between the two bolts, it is difficult get in there with wire twist pliers. My thought is to connect something between the two.
A's Always Dave |
01-27-2019, 06:05 AM | #8 |
It's not the space shuttle! Just drive it!
