Old 10-29-2018, 09:15 PM   #1
Bursonaw
Bursonaw's Avatar
Default 1941 Trunk Lock Issues
I’m trying to put an original trunk lock together in my 1941 Ford. Here’s the issue Im having. Using an NOS lock cylinder I can only remove the key with the trunk handle unlocked. When the handle is locked the key cannot be removed from the cylinder.
1. Do I have the wrong lock cylinder?
2. Is there another part that I’m missing inside the handle that will make it work properly?
I did bring the lock to a local locksmith and he was not able to offer any solutions.
Here are some pictures that might help to understand my issue.
The key can be removed when the cylinder is in the unlocked position. (The pin at the end of the cylinder is in the up position)
The key cannot be removed in the locked position. (The pin at the end of the cylinder is in the down position).
I made the square bolt with the notch in it for inside the trunk handle. Is there some other part that I’m missing to make this work properly?
I’d appreciate any help to resolve my issue.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 10-30-2018, 08:11 AM   #2
FlatHeadCoupe
FlatHeadCoupe's Avatar
Default Re: 1941 Trunk Lock Issues
The lock cylinders from 1941 through early '47 were designed to only release the key in the "locked" position. A modified cylinder was introduced in '47 that allowed the removal in either the "locked" or "unlocked" position. I may have a limited number of the "later" versions in stock.
Regards,
FlatHeadCoupe
FlatHeadCoupe is offline   Reply With Quote
Old 10-30-2018, 11:38 AM   #3
32phil
Amen to what Flathead Coupe replied.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 10-30-2018, 06:34 PM   #4
Bursonaw
Bursonaw's Avatar
Regards,
FlatHeadCoupe
Thanks for the reply. This is great information!
Old 10-31-2018, 01:13 PM   #5
drolston
drolston's Avatar
I put in the '41 trunk handle and keys from Dennis Carpenter and the key can be removed, locked or unlocked. Pain in the keester to install due to the big nut behind the mounting framework, but it can be done using a long screwdriver and a ball peen on that nut.
