Old 10-30-2018, 07:11 AM   #1
george1943
Default body roll and wallowing
[I know what body roll is, what is wallowing, from panhard bar discussions.
george1943 is offline   Reply With Quote
Old 10-30-2018, 07:27 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: body roll and wallowing
I am guessing it is someone's description of the effects from a worn-out front suspension!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-30-2018, 08:41 AM   #3
katy
katy's Avatar
Diagnoll body roll
Old 10-31-2018, 03:29 AM   #4
pooch
pooch's Avatar
Rear end loose as a goose sideways.
pooch is offline   Reply With Quote
Old 11-01-2018, 07:08 PM   #5
Tinbasher
Tinbasher's Avatar
On a Model A it would be caused by worn out shocks and brake pull.
Tinbasher is offline   Reply With Quote
Old 11-02-2018, 01:44 PM   #6
100IH
Pooch is right. Stops body from shifting R or L relative to axle. Really a problem with coil springs, less of a problem with transverse leaf springs. Watts linkage is similar but can help with body roll. Both systems are more often found at the rear.
100IH is offline   Reply With Quote
Old 11-02-2018, 08:41 PM   #7
heneste
heneste's Avatar
Another site mentioned if the car leans to one side the steering geometry changes so you have to constantly correct or over correct on your steering and the cars wanders around the road. They referred to this haphazard movement as wallowing.
heneste is offline   Reply With Quote
