Old 08-09-2017, 08:59 AM   #1
george1943
Default hand brake rebuild
Trying to find pics of a disassembled hand brake lever. the spring in mine disappeared. Can't find anything in faqs. 1929 tudor
Thanks, George
george1943 is offline   Reply With Quote
Old 08-09-2017, 04:47 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: hand brake rebuild
I'll have to see if I can find my spring, as mine is still apart.
Mine has the push button lever in front of the shifter. Mid 29 it moved to the right of the shift tower.
Old 08-09-2017, 07:06 PM   #3
SeaSlugs
SeaSlugs's Avatar
if its pushbutton it should go in this order from thumb down: pushbutton itself is held to the rod by a pin, under the button is the spring and the other end of the spring is supposed to catch on a lip inside the potmetal "teardrop" shaped piece thats pressed into the steel handle itself.
I have seen several times that lip is broken (potmetal cracks off) so your spring wont catch anything and is probably stuck inside the handle itself.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-09-2017, 08:51 PM   #4
Tom Wesenberg
I couldn't find my spring, so hopefully someone else has a picture of it.
Old 08-09-2017, 10:02 PM   #5
SeaSlugs
SeaSlugs's Avatar
its about 1.5" long and about the diameter of the "neck" of the pushbutton if i remember right.
Old 08-11-2017, 07:46 AM   #6
george1943
Thanks for the replies. I'll try and grind a washer to fit the hole and dig up a spring. Lever is in front and can't get it apart, nut is frozen.
Thanks again, George
Old 02-17-2018, 05:16 AM   #7
pyrodork
pyrodork's Avatar
Send a message via Yahoo to pyrodork
Macs has them on eBay. Look for Model A Ford Emergency Hand Brake Rod Spring, part number 28-22382-1. $1.25 plus shipping. I found one at a hardware store that worked, but at least I had a backup plan!
Current Classics:
1930 Ford Model A Tudor
1937 Plymouth P4 Deluxe 2-door touring sedan
1964 Ford Galaxie 500
Past Classics:
Early '30 Ford Model AA
1948 Dodge Deluxe 4-door sedan
1951 Studebaker Champion 2-door sedan
1988 Ford E-350XL Ambulance
pyrodork is offline   Reply With Quote
