Old 11-10-2019, 05:51 PM   #1
Gick70
Default 1951-1952 f1 hood
What hoods interchange with f1? F2,f3 and so on?
Gick70 is offline   Reply With Quote
Old 11-10-2019, 06:15 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 1951-1952 f1 hood
F1-6 share hoods.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 11-10-2019, 06:48 PM   #3
Gick70
Anything else they share by chance??
Old 11-10-2019, 08:14 PM   #4
FortyNiner
FortyNiner's Avatar
Cabs (including doors) and grilles are also the same. Fenders are shared by F2-6.
Old 11-10-2019, 09:12 PM   #5
Ross F-1
Ross F-1's Avatar
Actually hoods, cabs, and doors are shared by F1-F8. The big trucks often have better sheet metal because they are up out of the muck.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 11-10-2019, 11:46 PM   #6
mercman from oz
mercman from oz's Avatar
Did you know that for the 1948-1950 Ford Grilles, there we two different widths? On the Big trucks, the Grille was wider than on the smaller series. See the above pictures. From 1951 onwards, the F1, F100 shared the same Grille with the large trucks until 1967, when the Trucks got a differently styled Grille to the smaller trucks. These two trucks, are Australian, as you can tell by the location of the Parking Lights. Ford Australia adopted the same location as Ford of Canada did with their Mercury range of trucks.
Old 11-10-2019, 11:48 PM   #7
mercman from oz
Here is a Canadian F-47 (that is what the Canadian equivalents of the F-1 trucks are called) that was imported to Australia. Notice that the Canadian Ford Pickups placed the Parking Lights in the same location as the USA Ford Trucks.
Old 11-23-2019, 03:18 PM   #8
Gick70
Do the hoods interchange say 1949?
Old 11-23-2019, 05:18 PM   #9
FortyNiner
FortyNiner's Avatar
The latch mechanism is different between the 48-50 and 51/52 models. Was that your question?
Old 11-27-2019, 04:19 PM   #10
Gick70
Other than the latch different do they interchange?
Old 03-29-2020, 01:01 PM   #11
Gick70
Bringing this back up. 48-50 to 51-52 hoods the same other than the bolt in latch mechanism??
Old 03-29-2020, 04:01 PM   #12
Ross F-1
Ross F-1's Avatar
They "may" fit but they don't look at all the same, and the latch mechanism is totally different.
48-50 -- all the same
51 is unique -- 3 holes in nose, has different side and nose trim than a 52, V8 emblem on valance below hood
52 is unique -- 2 holes in nose, "FORD" on valance below, V8/6 emblem in center of nose trim piece
Tho each is unique, the differences between 51 and 52 are not great.
