Old 10-16-2019, 01:17 PM   #1
adileo
adileo's Avatar
Default Still needing advise on 52 F1
Recent tune up on all stock engine
Plugs
Wires
New points
Rotor and cap
Did not replace condenser.
Adjusted timing as advised in other post.
Changed fuel filter
Adjusted carb mixture
Trucks starts great cold or hot
Run well at idle
Cruise around town and 55-60 no issue
Problem is if I get on it - it doesn’t wind out, but bogs down. It feels like it’s lacking fuel. But that’s only my guess.
Thoughts?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-16-2019, 01:22 PM   #2
Charlie Stephens
Default Re: Still needing advise on 52 F1
Check to see if your accelerator jets are working.
Charlie Stephens
Old 10-16-2019, 02:10 PM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Does it backfire ??? Backfire + no fuel or very lean ...........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-16-2019, 02:25 PM   #4
adileo
adileo's Avatar
No back fire. Just bogs down when hitting gas peddle hard.
I’ll have to google accelerator jet. I’m not verse one crab parts
Thanks
Andy
1952 F1
Old 10-16-2019, 04:20 PM   #5
TJ
TJ's Avatar
Sounds like it is starving for fuel. Is there an in-line filter? Has it been changed? Have you removed the sender and looked in the tank? Is it clean? Are you sure you have the correct gas cap? I think your truck uses a vented cap. The symptoms you have are very similar to a car I once owned. Turned out somebody used some sealant around the sending unit and a small piece of sealant fell off and would partially block the gas line in the tank.
Old 10-16-2019, 04:47 PM   #6
Bruce_MO
I would also guess the accelerator pump, if it bogs instantly when you push the accelerator pedal down hard. With the engine stopped and the air cleaner off, you should see two distinct sprays of fuel (assuming it's a V8) coming out of the accelerator pump nozzle that shoots fuel down the bores of the carb above the butterflies when you stroke the throttle linkage pretty far. Easiest to do with the link from the gas pedal disconnected from the carb throttle arm. Google "holley 94 carb diagram" and you'll see an exploded view. Part #40 does the squirting. Part #33 is the accelerator pump plunger that pushes the gas out. It'll wear or shrink and you get poor action. I think the standard NAPA carb rebuild kits come with those. Good luck
Bruce_MO is offline   Reply With Quote
Old 10-16-2019, 05:02 PM   #7
adileo
adileo's Avatar
Thanks all good advise. Glass bowl fuel pump, rebuilt by CharlieNY last spring. Filter just changed.
One other point I failed to mention.
When putting putting timing light on. I disconnected the vacuum and taped off. Timed to mark and then reconnected. I then hit with timing light again and noticed it was in same position (right on mark). I also noticed there was some play in the vacuum disc when trying to reconnect the rigid vacuum line. Is there supposed to be some play in the vac disc?
Thanks
Andy
1952 F1
Old 10-16-2019, 05:15 PM   #8
JSeery
JSeery's Avatar
With the timing light connected do you see the timing advance at higher engine rpm's?
Old 10-16-2019, 05:20 PM   #9
adileo
adileo's Avatar
Jerry I didn’t try that but will and let you know, tomorrow
Thanks
Andy
1952 F1
Old 10-16-2019, 08:47 PM   #10
40cpe
40cpe's Avatar
If the screws that attach the vacuum can to the distributor aren't tight, you can feel some play.
40cpe is offline   Reply With Quote
Old 10-16-2019, 11:57 PM   #11
Ross F-1
Ross F-1's Avatar
Make sure the valve at the tank is completely open! Have you ever cleaned the screen in the valve, that sticks up into the tank? Have you done anything with the fuel line to the pump? That is the low point of the system and mine was so full of crap that I decided to just replace it. It made a big difference in how much brown sludge I'd find in the pump bowl and carb, even with filters.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-17-2019, 05:31 AM   #12
skidmarks
skidmarks's Avatar
I found the retainer pin fell out of the vacuum advance inside the distributor on a 8BA one time. Started fine but fell on its face when driving.
skidmarks is offline   Reply With Quote
Old 10-17-2019, 06:30 AM   #13
Ggmac
A possible that hasn't been mentioned, check your exhaust . A plucked exhaut will do that also . It's unlikely, but worth looking into .
Stick a vacuum gauge on it while driving.
Ggmac is offline   Reply With Quote
Old 10-17-2019, 07:10 AM   #14
adileo
adileo's Avatar
Thank friends
Ross - I took the fuel pump glass bowl off and even tho clean, I replaced the screen. What other screen are you mentioning, that sticks up into tank. I have a lift and can easily access the hose connected to the tank. Which btw looks new, like previous owner may have replaced.
Skid - where is the retainer pin inside the distro? Are you referring the points screws?
40cpe - the two screws that hold the distro are tight but there is a slight play in the vacuum tank. I noticed this when trying to reinstall the metal vacuum hose. that goes from the tank to the carb.
At work today, but off tomorrow, will try all suggestions.
Thanks
Andy
1952 F1
Old 10-17-2019, 07:52 AM   #15
corvette8n
corvette8n's Avatar
How's your vacuum, how much fuel pressure do you have? I think it's supposed 1-1/2 to 2-1/2 lbs someone correct me if I'm wrong.
Old 10-17-2019, 07:57 AM   #16
Ross F-1
Ross F-1's Avatar
Does your tank have a right-angle shutoff valve on the fuel connection? That is what is stock. On its inlet (part that screws into tank) there is a metal tube made out of brass screen that sticks up into the tank. You can't replace it without draining the whole tank.
You should be able to look down thru the filler and see if there is a bunch of crud in the bottom of the tank.
Old 10-17-2019, 10:44 AM   #17
adileo
adileo's Avatar
Don’t think I have that under tank. Will look tomorrow. Tank looks fairly new so probably reproduction
Thanks
Andy
1952 F1
Old 10-18-2019, 08:51 AM   #18
adileo
adileo's Avatar
I tried this morning and when reving the timing does advance.
One other thing I noticed. The timing mark does not change, vacuum connected or disconnected and taped at idle.
Still haven’t resolved yet.
Thanks
Andy
1952 F1
Old 10-18-2019, 10:06 AM   #19
JSeery
JSeery's Avatar
There is very little to no vacuum at idle, so that is normal. The distributor is seeing the vacuum from the carburetor ports, not manifold vacuum.
Old 10-18-2019, 10:12 AM   #20
adileo
adileo's Avatar
Jerry thanks. I will pull oil bath air cleaner and see if jets are working properly then put truck up on lift and check fuel lines, later this afternoon.
Thanks
Andy
1952 F1
