Old 10-16-2019, 07:18 AM   #1
adileo
adileo's Avatar
Default 52 F1 timing
I misplaced my shop manual.
All stock. When timing with a timing light are the marks lined up or 6 degrees btc?
Also is btc counter clockwise or clockwise to pin?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-16-2019, 07:59 AM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: 52 F1 timing
On the pin and let the distributor do the rest .....
http://www.vanpeltsales.com/FH_web/f...53_239-255.htm
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-16-2019, 08:12 AM   #3
adileo
adileo's Avatar
Thanks Jim
Curious
From front lookin in, Is btc counter clockwise to mark or clockwise.
Thanks
Andy
1952 F1
Old 10-16-2019, 09:56 AM   #4
40cpe
40cpe's Avatar
If you are looking at your marked crank pulley lined up with the pointer, up toward the top of the engine is advancing, or firing before TDC. The engine us turning clockwise (looking at the front of the engine), the farther "up" the pointer is from the timing mark the more advanced you are.
40cpe is offline   Reply With Quote
Old 10-16-2019, 10:21 AM   #5
Ross F-1
Ross F-1's Avatar
On V8 trucks with the pin lined up it is at 2 deg BTDC.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-16-2019, 01:04 PM   #6
adileo
adileo's Avatar
Thanks guys
Thanks
Andy
1952 F1
