12-03-2018, 11:14 PM | #21 |
Re: water pump bolt
BG you got lucky with the exhaust bolts, they are tough. Not my favorite. not sure why a lttile help with anti-seize is wrong?
I'm guessing head bolts are problematic due to torque stretching? |
12-03-2018, 11:39 PM | #22 |
Re: water pump bolt
Hi Just a note about Stainless hardware. Marine grade 300 series is available at Fastenal and speciality dealers. Most hardware stores do not carry 'marine grade' I have examples of the pump bolt SS corroded down to 1/2" head size. Newc
12-03-2018, 11:53 PM | #23 |
Re: water pump bolt
glad this question was raised, made me research it some. Interesting.
https://www.nutsandbolts.com/v10-sta...eel-grade.html neat read.. https://www.boltdepot.com/fastener-i...materials.aspx https://www.fastenal.com/content/doc...renceGuide.pdf Last edited by Tinker; 12-04-2018 at 12:16 AM. |
12-04-2018, 07:01 AM | #24 |
Re: water pump bolt
I just had a related thought. If you did use a stainless bolt, and it broke for some reason, you probably couldn't use the old "weld a washer and a nut on it" removal technique to get it out unless you have special welding equipment, could you? I think this biases me against stainless bolts in general.
12-04-2018, 07:21 AM | #25 |
Re: water pump bolt
I just use a decent used bolt, with a smidge of copper grease. I do always use antifreeze though, for it's corrosion inhibitor qualities.
Mart. |
12-04-2018, 08:02 AM | #26 |
Re: water pump bolt
12-04-2018, 09:31 AM | #27 |
Re: water pump bolt
Not entirely sure what the wrong is referring to, but the thing to keep in mind is anti-seize (or any lubricant) changes the torque value you can apply to a fastener. What you are wanting is clamping force and the clamping force is greatly increased when you apply the dry torque value to a fastener that is lubricated. This can result in two outcomes, you end up applying excess clamping force or you can potently break the fastener. So, if you use some type of lubricant on a fastener you need to look up the wet vs dry torque values. Most torque values you see specified are the "dry" values.
In practice this gets a bit messy as we rarely are dealing with clean new fasteners, so it is just something you might want to keep in mind. Last edited by JSeery; 12-04-2018 at 09:41 AM. |
12-04-2018, 11:30 AM | #28 |
Re: water pump bolt
I seriously doubt that any of the ones I've pulled had anti seize on them,
but yes, I always use it on reassembly for the next guy. Sometimes the next guy is me.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-04-2018, 12:21 PM | #29 |
Re: water pump bolt
Years ago, mechanics didn't use a torque wrench to install water pump bolts.
Tighten it firmly and then, move on. I think we are "over torquing" this bolt question. |
12-04-2018, 02:51 PM | #30 |
Re: water pump bolt
Agreed. I think someone here should do a test and omit these bolts altogether to see if anything bad happens. 8^) Jack E/NJ
12-04-2018, 02:54 PM | #31 |
Re: water pump bolt
Thirty responses and only one addressed the question posed??????
12-04-2018, 03:55 PM | #32 |
Re: water pump bolt
Thanks for all the responses, great thread. Pumps from GOTHAM AUTO PARTS, Bedford Hills, NY (ronnieroadster recommended, James is great ! !) arrived today (ordered y/day and well packed ! !). As some of you noted, if the bolt comes out OK I may just re-use but I did pick up S/S today.
Paul in CT |
12-04-2018, 04:05 PM | #33 |
Re: water pump bolt
I have never had a problem with the "hidden" bolt. As a body man dealing with rusty nuts and bolts, my sockets are all 6 point.
12-04-2018, 05:08 PM | #34 |
Re: water pump bolt
FWIW if you have a somewhat undersize 9/16" headed bolt, you might try a 14mm socket, it will be a tighter fit.
Mart. |
12-04-2018, 05:21 PM | #35 |
Re: water pump bolt
I agree with JSeery and Mart. I always use a 6-point 14 mm socket because it fits more snuggly. I use grade 8 for the hidden bolt with anti-seize, never stainless.
12-04-2018, 09:22 PM | #36 |
Re: water pump bolt
I thought this was a interesting read (although it's from the internet and I posted it previously on this thread). It explains SS bolts are around a grade 2, as mentioned by Newc, marine are more like grade 5.
https://www.boltdepot.com/fastener-i...materials.aspx Although this was a conversion about bolts, I feel like I learned something more. To add more to the conversion for conversion sake. Grade 8 hardness is not good for anything that has shear force on the bolts (like flywheels). Grade 8 is strong but very brittle. I guess in conclusion, regular steel 5 grade bolts are good to go. Also I'm not worried about it that much in most situations that are not that dire using ss and some anti-seize regardless of the "factory" torques (outside head bolts). Don't fool around with flywheels and bolts though! When in doubt give Roy a call. http://fordscript.com/ Last edited by Tinker; 12-04-2018 at 09:29 PM. |
12-05-2018, 04:34 PM | #37 |
Re: water pump bolt
Update
A lot of not needed worry, bolt came right out !! Water jacket behind pump beautifully clean !!. Have to do the other side now. Got too cold this afternoon to continue. Thanks again Paul in CT |
12-06-2018, 05:47 PM | #38 |
Re: water pump bolt
Allen heads wont strip or round off.
Even though its a low torque bolt, they can get cooked in there and cause problems getting them out. Either way use new hardware. |
12-06-2018, 11:02 PM | #39 |
Re: water pump bolt
Looks like I'm in the minority here on this one. On the only 59 series engine, that I've ever rebuilt, I had the hidden water pump bolt hex head snap off when attempting removal. So, when installing rebuilt pumps, I used SS bolts and anti-sieze on the internal/hidden bolt threads.
12-07-2018, 02:09 PM | #40 |
Re: water pump bolt
