Old 09-08-2018, 05:55 AM   #1
FrankWest
FrankWest's Avatar
Default Propylene Glycol
I am having trouble finding Preston LowTox, Propylene Glycol, Antifreeze.
Any help finding this or a suitable replacement will great be appreciated.
Thanks guys
FrankWest is offline   Reply With Quote
Old 09-08-2018, 06:23 AM   #2
flathead48
Default Re: Propylene Glycol
Frank/west, I having been looking for months Preston does not answer inquiries about it and neither will Peak when ask about their Serria
flathead48 is online now   Reply With Quote
Old 09-08-2018, 06:33 AM   #3
Yoyodyne
Yoyodyne's Avatar
Is RV P-G antifreeze the same thing or are there other additives for use in cooling systems? I've purchased that at K-mart.
Yoyodyne is offline   Reply With Quote
Old 09-08-2018, 08:17 AM   #4
jrvariel48
jrvariel48's Avatar
I think O'riely carries it
jrvariel48 is offline   Reply With Quote
Old 09-08-2018, 10:45 AM   #5
keith oh
keith oh's Avatar
NAPA carries propylene glycol (Sierra brand name) Expensive.
keith oh is offline   Reply With Quote
Old 09-08-2018, 05:36 PM   #6
42guy
42guy's Avatar
Yes NAPA has Sierra. Just got some about 1 month ago.
42guy is offline   Reply With Quote
Old 09-08-2018, 05:50 PM   #7
40 Deluxe
Just use ethylene glycol and avoid the headaches!
Old 09-09-2018, 07:16 AM   #8
jrvariel48
jrvariel48's Avatar
I couldn't use ethylene, it kept foaming in my radiator. I posted that problem here and someone directed my to use propylene and I haven't had a problem since
Old 09-09-2018, 08:55 AM   #9
JSeery
JSeery's Avatar
This stuff is not cheap! But it is available.
Amazon https://www.amazon.com/Old-World-SEP.../dp/B000CCM5JA
Ebay https://www.ebay.com/itm/Sierra-Anti...gAAOSwp~9bhEMU
Walmart https://www.walmart.com/ip/Sier-Gal-...-of-6/39087769
Old 09-09-2018, 09:41 AM   #10
tubman
tubman's Avatar
Boy, that stuff had better be GOOD!
Old 09-09-2018, 10:19 AM   #11
JSeery
JSeery's Avatar
I think these are 6 packs, so it is around $23/gallon. But it is expensive.
Old 09-09-2018, 10:53 AM   #12
tubman
tubman's Avatar
That's a relief; it took me a while to ferret that out. I saw the initial price and freaked out. All three sources seem to sell only 6 packs though; I wonder why?
Old 09-09-2018, 12:01 PM   #13
Jack E/NJ
Jack E/NJ's Avatar
>>>I couldn't use ethylene, it kept foaming in my radiator.>>>
I don't think propylene glycol will change a foaming situation. Sounds like it may either have a minor head gasket 'gas' leak in the compression/power stroke or somehow entraining a lot of air above the coolant while its pumping. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 09-09-2018, 12:40 PM   #14
Ronnie
Ronnie's Avatar
https://p.acehardware.com/department...freeze/8068090
Ronnie is offline   Reply With Quote
Old 09-09-2018, 01:00 PM   #15
tubman
tubman's Avatar
Again, a minimum on-line order of 6 gallons.
Old 09-09-2018, 01:05 PM   #16
FrankWest
FrankWest's Avatar
you use half antifreeze with half distilled water, right?
Old 09-09-2018, 02:13 PM   #17
FL&WVMIKE
FL&WVMIKE's Avatar
Propylene Glycol is installed FULL strength... no cutting it with water. Here is a product called Engine Ice... which is formulated with Propylene Glycol. Motorcycles and ATVs use it more than cars, as it's quite expensive.
The price is $23.45 for a half gallon. Expensive, indeed. It can be found a little cheaper, but it's still not exactly cost friendly to put in a flathead!
https://www.amazon.com/dp/B000H01NFY..._t1_B000BRGAJ2
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn.
FL&WVMIKE is offline   Reply With Quote
Old 09-09-2018, 02:21 PM   #18
FrankWest
FrankWest's Avatar
really full strength? wow do you live at Ice Station Zebra?
Old 09-09-2018, 03:41 PM   #19
Jack E/NJ
Jack E/NJ's Avatar
I doubt it. Jack E/NJ
Old 09-09-2018, 03:45 PM   #20
FL&WVMIKE
FL&WVMIKE's Avatar
From the link I posted...
Ready to Use
Engine Ice Hi-Performance Coolant is pre-mixed with de-ionized water.
Most of the Propylene Glycol products I've seen come pre-diluted... like 50/50 antifreeze. Be sure to read the fine print on whatever product you are looking to purchase.
Good Luck
Thread Tools
Display Modes
