03-05-2018, 04:34 PM | #1 |
venturi removal tool
Hi Guys, need some help here. I'm trying to understand HOW THE VENTURI REMOVAL TOOL ACTUALLY WORKS. I HAVE THE CARBURETOR REBUILD BOOK BY Paul Moller WERE HE SHOWS HOW TO MAKE ONE BUT FAILS TO EXPLAIN HOW TO USE IT. I've searched this site with no success. any help will be greatly appreciated thanks THE HOOCH
03-05-2018, 04:57 PM | #2 |
Re: venturi removal tool
Look at this:
https://www.model-a.org/venturi_extraction.html
03-06-2018, 12:15 PM | #3 |
My Zenith has a very loose venturi...could this be the reason why I cannot get my A to idle properly? Should the venturi fit snugly in the body?
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
03-06-2018, 12:31 PM | #4 |
They can be made with a piece of all-thread, a couple of nuts, washers and a rubber plug.
Double nut the bottom> washer > rubber plug> washer > and the last nut. Put the plug into the venturi, tighten the top nut until the rubber plug expands inside the venturi and tightens up gripping the venturi and simply pull it out. If it's stuck in real good, you will need to use a penetrating oil FIRST regardless of which method is used to remove the venturi. The rubber plug method is really the only one to safely remove them without the fear of damaging it an any way, unless they simply fall out like one of my (3) Zeniths-1 did. Regards Bill |
03-06-2018, 02:51 PM | #5 | |
Removal.... they can be an absolute B*****, , they can be seized into the U and L body castings. splitting when you separate the bodies . it's then you often find that someone has previously mangled them trying to effect removal, Try penetrating oil, puller, gentle tapping of central section of puller with hammer, heat and more tapping ditto , thermal shock ( in that order) .... and I had one today that someone had so severerly b*ggered in the throat of the lower body that I had to melt it out with an acteylene/propane torch. Last edited by johnbuckley; 03-06-2018 at 03:04 PM. |
03-06-2018, 03:47 PM | #6 |
Not my favorite carb - but works well as a spare below the seat. Joe K
Shudda kept the horse. |
03-06-2018, 04:29 PM | #7 |
Grab the shaft on your butterfly valve and see if there is movement where it passes through the side wall of the carburetor. If worn it can pull too much air in through there causing idle problems.
Dave / Lincoln Nebraska |
03-06-2018, 08:34 PM | #8 |
I had to torch a couple venturi out, but be sure to wear a full face shield, because that pot metal likes to splatter when heated.
03-06-2018, 10:38 PM | #9 |
I am surprised that nobody has yet mentioned an old and effective trick for removing a stuck venturi!! Place the assembly in oven at 400 degrees Fahrenheit for 10 minutes. Remove assembly and place in paper bag and place this in the freezer for another 10 minutes. Remove the bag and tap softly on a piece of wood and the venturi will fall out. Works for me.
03-07-2018, 07:20 PM | #10 |
I would think 400° would cause the paper bag to ignite and or melt the inside of your freezer.
YES, ... that kind of expansion and contraction would certainly do the trick without the use of penetrating oil. Regards Bill |
