05-30-2013, 03:36 PM | #1 |
transmission install 39 ford
Is it easier to install transmission separate from engine on these closed drive shaft Fords. My other truck which I put the engine in is 47. THANK YOU for any advice SUNSHINE
05-31-2013, 04:52 AM | #2 |
Re: transmission install 39 ford
Installing the trans seperately is ok but, you need to hook the drive shaft spline before sliding the engine back onto the motor mounts. |
