11-08-2018, 11:33 PM | #21 |
Re: Optima 6V batteries production
I agree about the looks, but I like the performance. I'm good with the look as I'm not a points guy and don't mind the questions. Most questions about it are more about how they they run.
11-09-2018, 03:10 AM | #22 | |
https://www.ebay.com/itm/Original-St...wAAOSwqu9UzxkP
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
11-09-2018, 08:40 AM | #23 | |
Your mileage may vary.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
11-09-2018, 10:22 AM | #24 |
11-09-2018, 10:37 AM | #25 |
11-09-2018, 10:51 AM | #26 |
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
11-09-2018, 11:01 AM | #27 |
The battery in my 40 wagon is an optima inside of a case that brought no deductions on 2 different EFV8 concourse judging events. (scores 969, 987). You don't have to have it looking like an optima.
Last year a PhD battery engineer spoke at our Regional Group meeting on batteries and said that ALL batteries, including AGMs benefit from being on tenders as it extends their life. |
11-09-2018, 11:50 AM | #28 | |
11-09-2018, 12:00 PM | #29 |
For what its worth....I installed an Optima 6-volt redtop in one of my non-Ford cars in 2003. That darn thing only lasted until 2016. Yup, just 13 years. And it was on a car that gets driven a lot and has big, long stroke, 468 CID engine that needs to get cranked over. I have one in a Model A that is probably 7-8 years old and still works fine. It goes without saying that both cars have properly operating charging systems with proper and clean electrical connections from bumper to bumper.
I always keep them on a very good quality tenders, not the cheap kind. Needless to say, I am a happy customer and certainly hope that production of the 6V Optima continues. Last edited by gz; 11-09-2018 at 12:07 PM. |
11-09-2018, 12:05 PM | #30 | |
I am getting the feeling that this is a 6V thing.........anyway both are "wet acid" and not maintenance free. Last edited by Merc Cruzer; 11-09-2018 at 01:05 PM. |
11-09-2018, 01:01 PM | #31 |
I saw 'fake' original looking cases that were designed to conceal an Optima battery inside.
https://www.ebay.com/itm/Original-St...d=232967591550
11-09-2018, 02:32 PM | #32 |
11-09-2018, 02:40 PM | #33 |
11-09-2018, 04:17 PM | #34 |
I don't seem to find any Utube videos on how to replace the Optima battery's in the original style battery cases. It is always interesting to see the different approaches to the same question.
11-09-2018, 04:48 PM | #35 |
There have been past threads on gutting an original battery case and building it back up around an Optima battery. I understand an increase in battery height has made this a little more difficult. There are also threads on constructing battery cases from scratch.
11-09-2018, 10:38 PM | #36 |
Checked out Optima site:
"Because of the high-purity lead grid in the OPTIMA battery, it has a self-discharge rate much lower than conventional flat-plate batteries. This means the OPTIMA battery can sit for longer periods retaining enough charge to start your vehicle when stored and maintained properly. Depending on storage temperature and the state of charge when put into storage, it can usually sit for eight to 12 months and still start most vehicles. When possible, store your battery in a cool, dry location. Check the battery voltage every six months and charge if it falls below 12.4 volts. Remember, newer vehicles with onboard electronics such as computers, LCD screens, game systems, GPS units, clocks, etc., require battery power to retain system memory while the vehicle is parked. If the vehicle is to be stored for long periods, you should use a maintenance charger to compensate for this drain. During maintenance, the voltage should be regulated between 13.2 and 13.8 volts, one amp maximum. On older vehicles without electronics, disconnect the battery cables when the vehicle is not being used for extended periods." |
11-10-2018, 05:15 AM | #37 |
If all you fellows keep calling maybe they will start sooner on production. Don't hurt
11-11-2018, 02:30 AM | #38 |
11-11-2018, 08:32 AM | #39 |
I bought one at NAPA last week. Over the counter...
11-11-2018, 04:10 PM | #40 |
We get ours from our local Interstate Battery dealer.
