12-12-2014, 12:10 PM | #1 |
39 open drive transmission to closed drive
Probably not asked much but what is needed to convert a 39 3sp transmission with an open drive setup back to a closed drive (torque tube) setup.
Would the output shaft need to be changed? Also would the early 4sp transmission yoke and parts work also? This is for a 39 truck currently with a 4sp truck transmission (not mine). Thanks for any help. Last edited by Tinker; 12-12-2014 at 12:16 PM. |
12-12-2014, 12:26 PM | #2 |
Re: 39 open drive transmission to closed drive
Here are the parts required to convert TO open drive. DD
12-12-2014, 12:28 PM | #3 |
Need to go the other way...
12-12-2014, 12:29 PM | #4 |
Seems to me there should be someone with a closed drive shaft trans wanting to convert to open that would be willing to work out some type of trade. JMO.
Making the simple complicated for over 30 years. |
12-12-2014, 12:30 PM | #5 |
I understand, but to answer one of your questions, you need to replace the mainshaft. DD
12-12-2014, 12:33 PM | #6 |
Have a couple transmissions to possibly use parts from. 4sp truck and a 40s sideshift (both closed drive) |
12-12-2014, 12:34 PM | #7 |
The side shift should have all the parts needed. DD
12-12-2014, 12:38 PM | #8 |
That's promising.
Any tricks to removing the mainshaft? Are they pinned? Any bearings or seals that are good to replace at this time? Just trying to get info before taking it apart. |
12-12-2014, 12:43 PM | #9 |
You'd be smart to swap the entire guts of the '40 box into the top-shift box as a set. Replace bearings, etc. as a judgement call. Mac VP's book will help you thru all of this, as well as Mac's parts availability. DD
12-12-2014, 12:45 PM | #10 |
Problem with that is the 39 transmission is a new rebuild. I believe I have that book I'll need to go dig for it.
12-12-2014, 01:13 PM | #11 |
Nope don't have it. I'll have to do a spline count on the 40 as I see a listing for 40s transmissions having 6 and 11 spline output mains.
Thanks. |
