Old 08-20-2019, 07:09 AM   #1
Ed in Maine
Default 1931 Cabriolet Rumble Lid
I am getting the rumble lid ready for paint. I noticed that at the bottom edge there are no drain holes. Any water that would get in thru the handle would collect in the bottom of the lid. Would it be a good idea to drill (3) 1/4 in. holes along the bottom? Is there any downside to doing this? Ed
Old 08-20-2019, 07:45 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: 1931 Cabriolet Rumble Lid
Wouldn't hurt I suppose; thru the years they have rusted out at the lower edge.
Theoretically, the only place water should get in is around the handle or wick thru the latch on the edge....possible. Make sure the weep holes are in an appropriate place to drain; probably closer to the bend in the inner liner??
Might spray some paint down in there if you can.
I'd probably do nothing!!!
Old 08-21-2019, 12:06 AM   #3
CWPASADENA
CWPASADENA's Avatar
It would not hurt to drill some drain holes.
I am also in the process of getting a rumble lid ready for paint.
I plan to get some Rust encapsulating paint down inside in this lower area.
Theoretically, there should be no water in this area but I would definitely do some preventative measures.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
