08-19-2018, 10:40 AM | #1 |
Thread size tie-rod 'plug'?
I have a seized tir rod end plug (the threaded end that screws down against the inner spring/ball). I am currently cutting out the plug and want to chase the inner threads before installing a new plug. What is the thread size? It appears to be fine pipe threads but I could be wrong...
"I have not yet begun to defile myself." -Doc Holliday '31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex |
08-19-2018, 12:00 PM | #2 |
Re: Thread size tie-rod 'plug'?
Here is an old "thread" on the subject..
https://www.fordbarn.com/forum/showthread.php?t=23581 I don't think they ever got around to answering your question, but these recent pictures show what I measured...that is a SAE 20 pitch gauge....hard to read in the picture. .
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 08-19-2018 at 12:12 PM. |
08-19-2018, 12:14 PM | #3 |
It is straight thread not pipe.
I know the voices aren't real but damn they have some good ideas! |
08-19-2018, 01:06 PM | #4 |
Assuming you don't have one, The tool of choice would be an enormous screw driver tip that fits a 1/2" ratchet, fits like a glove is by far the best.
08-19-2018, 03:14 PM | #5 |
There Snap-on sockets in various sizes that they made, and they are called drag link sockets.
08-19-2018, 03:46 PM | #6 |
Bob Bidonde |
08-19-2018, 09:28 PM | #7 |
Bob, didn't you mean to say 20 threads per inch? 1955cj5 showed a thread pitch gauge on the nut 20 threads per inch.
08-20-2018, 10:33 AM | #8 | |
I already broke the Bratton's Tie Rod End socket adapter tool. What I got is an end plug that will turn out about 1/4 of a turn and then just dead stops. It HAS to be the threads that are jacked-up. I can turn it back and forth...but, again, no more than 1/4 turn total of travel. I already bent a nice Snap-on screwdriver before I got the Bratton's tool.
08-20-2018, 10:55 AM | #9 |
There is such a thing as a 1"-20 H4, Plug Chamfer Tap. This has to be what they used back in the day. A tap like that runs nearly $50!!! Let's hope it's not the threads...the attempt to insert a new plug will tell all.
08-20-2018, 11:42 AM | #10 |
08-20-2018, 11:53 AM | #11 |
I think you need a 1 1/16x24 tap? Bratton's old catalog said it's 1 1/16 x 24 .
08-20-2018, 01:25 PM | #12 |
That's what I was kind of getting at... I just like to preserve the original parts if I can...within reason of course... A local machine shop I called says they'll chase the threads for me for $10 and a Coke.
08-20-2018, 07:23 PM | #13 |
Ours is 1-1/16 X 20. braol, that would be the way to go. Taps that size are not cheap anyway.
08-20-2018, 09:16 PM | #14 |
I had one that was stuck so bad it wouldn't turn even after I got the tie rod end white hot. It twisted the tie rod beyond saving.
08-21-2018, 01:15 PM | #15 |
I have an archive print for the drag link, it is 1-1/16-20
08-23-2018, 05:50 PM | #16 |
Thanks
