Old 03-19-2020, 12:51 PM   #1
lignell
Default 39 ford
my front window when I crank it out it sometime sticks and is difficult to crank back in what could cause thank you
lignell is offline   Reply With Quote
Old 03-19-2020, 12:55 PM   #2
marko39
Default Re: 39 ford
Most likely your mechanism needs to be lubed. Do you know the last time it was done?
marko39 is online now   Reply With Quote
Old 03-19-2020, 01:06 PM   #3
lignell
Default Re: 39 ford
a ong
a long time what is the proper way to lube it thank you
Old 03-19-2020, 02:08 PM   #4
swoopNZ
MEMBER EMERITUS
Default Re: 39 ford
Sometimes the arms tend to catch through the slots.
You can feel them under the dash.
Also some WD40 or similar may help lubricate the crank mechanism - again probably need to do it from under the dash.
swoopNZ is offline   Reply With Quote
Old 03-19-2020, 03:12 PM   #5
lignell
Default Re: 39 ford
thank you
Old 03-19-2020, 03:12 PM   #6
lignell
Default Re: 39 ford
thank you
Old 03-19-2020, 03:42 PM   #7
frnkeore
frnkeore's Avatar
Default Re: 39 ford
Could we get a picture of the'39? They are my favorite car, my dad bought one new a Deluxe Tudor.
That's me on the left.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 03-19-2020, 04:15 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 39 ford
What were they pointing at? Certainly, it couldn't have been the Hindenburg. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-19-2020, 05:24 PM   #9
lignell
Default Re: 39 ford
if you search 39 fords hemmings mine is the Dartmouth green which is for sale
Old 03-19-2020, 08:43 PM   #10
Graeme / New Zealand
Graeme / New Zealand's Avatar
Default Re: 39 ford
You being an aviation nut would have known that it couldn't have been...gave me a good laugh though.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 03-20-2020, 12:53 AM   #11
frnkeore
frnkeore's Avatar
Default Re: 39 ford
That's me on the left, my Gfather in front of me, we were at his farm in the Ozarks of AR. I was about 5 then (1949/50) so, I really don't remember but, my guess would be a chicken hawk.
My dad (not in the pic) worked at Meyer and Welch (authorize Ford Rebuider), at that time and the car had a 48 engine in it.
Frank
'35 Ford Model 51
'48 Ford F3
Old 03-20-2020, 05:16 AM   #12
Terry,OH
Terry,OH's Avatar
Default Re: 39 ford
If your going to lubricate anything do not use WD-40 it is not a true lubricant. It is Water Displacement product. Lots of much better true lubricants to use.
Old 03-20-2020, 09:19 AM   #13
marko39
Default Re: 39 ford
With this in mind I would disconnect windshield from mechanism and see where it is sticking. If it is the mechanism it should be removed for inspection and lube. Over time the gear gets worn and may need to be replaced. In meantime use a helper to push windshield from outside when closing.
Old 03-20-2020, 01:54 PM   #14
Aarongriffey
Default Re: 39 ford
Thank you Terry! Any locksmith or clock repair guy will tell you never spray WD40 in a clock or lock.
A few years ago a car collector I was working for had a ‘61 Lincoln that you had to jiggle the ignition key to turn it on.
So I gave it a shot of WD and it never worked again, even one time, until I took the switch to a locksmith.
It works pretty good on window channel though. And kills termites.
Aarongriffey is offline   Reply With Quote
Old 03-20-2020, 02:14 PM   #15
hotrodart
hotrodart's Avatar
Default Re: 39 ford
My '35 had a similar issue......a bit of white lithium grease solved it.......now cranks in/out with ease.
hotrodart is offline   Reply With Quote
Old 03-20-2020, 02:30 PM   #16
nelsb01
nelsb01's Avatar
Default Re: 39 ford
I was going to say -- "Look, up in the sky. Its a bird. Its a plane." But Superman didnt start until 1952.
nelsb01 is offline   Reply With Quote
Old 03-20-2020, 04:24 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 39 ford
Ah ah.....not so fast, there. The TV series didn't begin 'til '52. But the
character was created by writer Jerry Siegel and artist Joe Shuster, and first appeared in Action Comics #1, a comic book published on April 18, 1938. So....MAYBE it could'a been....? DD
T5 W/TORQUE TUBE
Old 03-20-2020, 04:53 PM   #18
lignell
Default Re: 39 ford
thank you
Old 03-20-2020, 04:55 PM   #19
lignell
Default Re: 39 ford
thanks access is difficult
Old 03-21-2020, 10:51 AM   #20
TJ
TJ's Avatar
Default Re: 39 ford
You can get spray lithium with the plastic tube to get into difficult places. You symptoms sound more like worn gears. Gears are pot metal and they do wear.
