07-05-2010, 03:20 PM | #1 |
Hole in the block?
Just confirming, that the hole found in the front of the valve chamber immediately behind the cam gear is supposed to be there? About a two by two inch hole in the casting. I question it, because it seems it is to low to allow oil to overflow into the middle and rear oil reservoirs.
07-05-2010, 03:46 PM | #2 |
Re: Hole in the block?
It is there on purpose as an overflow to the cam gear. I don't know the spec height but it should have a curb. I built mine up a bit with J-B Weld just to make sure it wasn't too low because it had an irregular shape. I evened it off across the top.
07-05-2010, 04:38 PM | #3 |
