Old 10-12-2018, 12:40 PM   #1
nosoup4u
Default Can someone tell me the name of this seal and where to fine it?
Looked in paper catalogs and online. Perhaps if I knew its proper name. The ones in the coupler that hold the torque tube to the tranny.
nosoup4u is offline   Reply With Quote
Old 10-12-2018, 12:55 PM   #2
barnstuf
Default Re: Can someone tell me the name of this seal and where to fine it?
It is usually sold as part of the universal joint gasket set, Snyders A-7090-GS, Brattons 10400 gasket set. They are felt.
barnstuf is offline   Reply With Quote
Old 10-12-2018, 01:28 PM   #3
100IH
Some times cork. Either works.
100IH is offline   Reply With Quote
Old 10-12-2018, 02:52 PM   #4
nosoup4u
thanks
Old 10-12-2018, 06:25 PM   #5
Dodge
felt is easier to use if you haven't done it before.
Dodge is offline   Reply With Quote
Old 10-12-2018, 07:08 PM   #6
modelAsteve
modelAsteve's Avatar
Can also use wiper vacuum hose
modelAsteve is offline   Reply With Quote
Old 10-13-2018, 10:49 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Lots of grease goes on the bell, as it moves with every bump.
Lots of grease goes inside the bell to lube the U joint.
Old 10-14-2018, 08:53 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
http://www.mikes-afordable.com/product/A4515GS.html
