Old 11-17-2012, 05:35 PM   #1
JtownJoe
JtownJoe's Avatar
Default Water pump end play
Changing the head gasket on my 30' & noticed there is about 3/16" in & out free play in the water pump. What is considered a normal amount, if any?
JtownJoe is offline   Reply With Quote
Old 11-17-2012, 05:51 PM   #2
H. L. Chauvin
Default Re: Water pump end play
Some recommend 0.006 to 0.0010 end play -- 0.006 sounds better.
One quick fix is to install a water pump shaft thin collar with a Teflon washer sold by vendors for under $4.00 to take up end play -- install immediately prior to installing fan -- fan hub hides it.
H. L. Chauvin is offline   Reply With Quote
Old 11-17-2012, 06:11 PM   #3
JtownJoe
JtownJoe's Avatar
Thanx for the input, I looked it up in Bratton's catalog & that's exactly what I will do. Thanx Again.
Thread Tools
Display Modes
