Old 01-31-2019, 08:09 PM   #1
Chuck Dempsey
Chuck Dempsey's Avatar
Default Another nice old pic....
Floating around on FB . . . . .
Chuck Dempsey is offline   Reply With Quote
Old 01-31-2019, 09:02 PM   #2
mhsprecher
mhsprecher's Avatar
Default Re: Another nice old pic....
A chain drive Model A. Who knew?
mhsprecher is offline   Reply With Quote
Old 02-01-2019, 02:25 PM   #3
1931 flamingo
1931 flamingo's Avatar
Ingenuity at work.....................
Paul in CT
Gotta "hand it" to the old timers.
Old 02-01-2019, 02:40 PM   #4
Werner
Werner's Avatar
This is a railroad "Draisine". In the war or in India?
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 02-01-2019, 04:15 PM   #5
petehoovie
petehoovie's Avatar
Old 02-01-2019, 05:08 PM   #6
30 Closed Cab PU
Does the car swivel to reverse direction?
Looks like there is something between the wood frame of the rail car and the wood frame of the A, towards the middle of the car
Looks like both A rear wheels have chains going to the gears on the rail car wheels. Also the other wheel shown without chain also has a geared wheel.
Remove chains, swivel the car around, chains back on, go the other way.
Old 02-01-2019, 05:12 PM   #7
Synchro909
Synchro909's Avatar
I noticed that the pivot for changing direction is positioned so that the weight of the engine keeps tension on the chain.
I want to live forever.
So far so good.
Old 02-01-2019, 05:24 PM   #8
1ton
You got 200 tons of steam engine barreling down on you. You drop the chains, spin her around and get the hell out of there
1ton is offline   Reply With Quote
Old 02-01-2019, 06:01 PM   #9
Joe K
Joe K's Avatar
Reminiscent of a pix over at "Old Motor."
Opinions varied but this appears to be a "self powered" float to move this car (possibly a Chevrolet) using onboard power and direction. The "depressions" in the drive-on wheel channels suggest it - as well as the "propulsion wake."
Some have opined that the boat ahead is towing the float/car - but no tow-rope is evident.
One comment at the site http://theoldmotor.com/?p=168804
The first photo may be Howard T Powers demonstrating his “Automobile Boat” near Corpus Christi, for which he and fellow Corpus Christ inventor Walter C Lewis received patent 1804262 on May 5, 1931. Apparently depression conditions sank any chance of commercial development for Powers.
Joe K
Shudda kept the horse.
Old 02-01-2019, 06:08 PM   #10
30 Closed Cab PU
Couple of outrigger pontoons would be nice. Does not look like it would take much for it to flip 180 degrees for submarine use.
Old 02-01-2019, 06:28 PM   #11
burner31
burner31's Avatar
Bet that was rough on th clutch
Keith
Shawnee OK
'31 SW 160-B
Old 02-01-2019, 11:56 PM   #12
BN
Looks like the "Train Car" was a slow moving affair. The speed reduction in the chain drive looks like somewhere between 3:1 - 4:1 . However, anything over 25 mph looks like it might be a bad idea. No brakes either.
Bill Newland
BN is offline   Reply With Quote
Old 02-02-2019, 12:03 AM   #13
Synchro909
Synchro909's Avatar
I think the rear brakes on the car would slow the trolly.
So far so good.
