09-22-2019, 12:40 PM | #21 |
Re: Unusual carburation on Flathead V8’s
09-22-2019, 12:43 PM | #22 | |
I don't think there is an adaptor for a spread bore four barrel carb to a small base four barrel manifold. That setup looks like the air slams into a wall. I'm sure it would cause turbulence. Sal |
09-22-2019, 12:44 PM | #23 |
Russ, or how about two Carter side drafts as used on a 188 Gray Marine....just say'n.
I think Interceptor Marine {Y-Block} used this set up too. m |
09-22-2019, 12:45 PM | #24 |
One of the best setups, ever.
09-22-2019, 03:01 PM | #25 |
09-22-2019, 04:01 PM | #26 |
But I'm lovin' the thought of I-Talian Testa-Rossa bits on your Ford. Just not lovin' that price tag.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
09-22-2019, 07:04 PM | #27 |
The only good thing that came out of this whole thing is that when I was running the numbers on a couple of Quadrajets I had to get the proper kits, I found out one was from a 1979 390 HP 454 Corvette. I sold it on eBay for $400 (matching numbers Corvette guys). It was the best core I had; I was reduced to using a core from a very dirty '75 Oldsmobile; I don't know if it was my deficit in rebuilding it or just a bad core.
I am going to get back into this some day, but I think one of the posters above was right; the next time I dive into this I am going to make an adapter that hast four individual throttle bores instead of the open plenum I originally used. Last edited by tubman; 09-22-2019 at 07:17 PM. |
09-23-2019, 06:07 PM | #28 |
09-23-2019, 06:16 PM | #29 |
09-23-2019, 06:54 PM | #30 |
09-23-2019, 08:12 PM | #31 |
09-23-2019, 08:52 PM | #32 |
09-23-2019, 08:55 PM | #33 |
09-25-2019, 01:14 AM | #34 |
I'm using Edelbrocks new 500 CFM AVS2 4 barrel ,great throttle response and fuel economy.
Did need major tuning with AFR meter thought. Ugly and too modern , but under the hood of ´50 Conv and air cleaner I can live with it .... |
09-25-2019, 11:13 PM | #35 |
Photos of unusual set ups on the Ford V8 engines the first one was on a V8 Coupe being raced.
09-25-2019, 11:30 PM | #36 |
09-26-2019, 01:09 AM | #37 |
I’ll try to figure out how to put pictures up. We have a Flathead we put a blower and Holley fuel injection on. Works great.
09-26-2019, 12:16 PM | #38 |
REALLY nice pictures, Ian!!! Awesome!
09-26-2019, 01:30 PM | #39 |
09-26-2019, 01:36 PM | #40 |
I would say, probably so.
My guess is was originally a '32 manifold, made to look like a later 2 barrel Probably shorten, too. I think it would have been higher than the hood, to show them off!! |
