10-28-2020, 02:07 PM | #1 |
32 V8 engine short block
City:
Kerrville
State:
Texas
Price:
$1000
Clean no crack, no rust 32 short block. Bored .030 recently, no ridge.
11-11-2020, 11:59 AM | #2 |
Re: 32 V8 engine short block
I took it apart for checking and freshing it up. I have not taken the crank out. The cylinders show no wear. The valves and seats are fine. The cam and crank are later. I believe a fresh set of rings would be all it needs. It has the press on timing gear that should be replaced also. I started removing the rings as that was what I intended to do. It was in a hot rod as it is paintd red and has been relieved. The owner had a famous California gold full fendered roadster and I think this is engine may have came from that car. It is very clean and undamaged. Correct 32 V8 engine with the straight down water cocks. Last edited by Andy; 11-11-2020 at 12:05 PM. |
