Old 11-30-2018, 02:26 PM   #1
51woodie
51woodie's Avatar
Question '46 Speedometer Removal
What is involved to remove the speedometer from the dash. I know the cable and light sockets need to be removed, but what holds it in the dash? Does it come out from the back or front? A description and pictures would be appreciated. Does anyone have a picture of the back side of an assembled dash?
51woodie is offline   Reply With Quote
Old 11-30-2018, 03:38 PM   #2
Sal
Default Re: '46 Speedometer Removal
There are a few common head screws that attach it from behind. It is removed from the back.
Sal is offline   Reply With Quote
Old 11-30-2018, 06:45 PM   #3
woodiewagon46
There are two tabs, one at about the 10 o'clock and one about the 5 o'clock position that the screws go thru. You need to be a contortionist to get to them. It comes out the back.
woodiewagon46 is offline   Reply With Quote
Old 11-30-2018, 09:50 PM   #4
FortyNiner
FortyNiner's Avatar
Front / back views. Removing the speaker grille makes for much easier access.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 12-01-2018, 08:08 AM   #5
51woodie
51woodie's Avatar
Thanks for the pics 49'r. The next question is, how do you remove the speaker grill. I have had the glove box out to work on the wipers, but didn't think about the speaker grill
Old 12-01-2018, 11:16 AM   #6
Drbrown
Drbrown's Avatar
I have a '47 but with the chrome-plated aftermarket grille replacement .... mounting method should be very similar. The center grille on the dashboard has a threaded stud in each corner. Its tight spaces but you need to get behind the grille and unbolt those 4 corners, two of which are back up in by the wiper linkage.
Drbrown is offline   Reply With Quote
